Re: Can you comp midi?
In the edit window, select from the menu "views > edit window views > instruments". That shows you the midi routing and settings for each track. On the instrument track you will notice that there is a little mute button in the midi section - that mutes the MIDI information, not the audio output on the track. Use that to mute the midi from that track while still hearing other midi sent to the instrument plugin. So next, create a new midi track above the instrument track you want to comp. Set the output of that new midi track to same instance of the instrument on your instrument track. (If you don't know which instance it is, open the instrument plugin and look in the top left corner, there should be a small text there telling you which instance it is). So now, you can unmute the midi section on your instrument track and go through each playlist, selecting the bits you want, separate them using command-E, option drag them up to your midi track on the track above. Just use your mute buttons between the instrument tracks midi section and the mute button on the midi track to control which one is playing, so you don't have both playing at the same time. When you have finished comping, you can create a new playlist on your instrument track, and drag your midi down onto it from the midi track above. Hope that makes sense! :)
Steve Peach Stereo Missile Recordings Creative Director - Red Note Visionary Sounds: http://rednote.com.au Label: http://www.stereomissile.com/ Music Production / Mixing: http://www.stereomissile.com/musicproducer/ Mastering: http://www.stereomissile.com/mastering/ |
its 2015... and protools still doesn't have proper midi playlists....
set a section on loop, record.. i want playlist lanes afterwards. to pick the best bits. |
PT is just missing the playlist view function, so you have to create new tracks, one for each playlist.
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
midi track record turns off all other midi/instrument tracks delay comp | holyspicoli | Virtual Instruments | 4 | 07-18-2013 06:14 AM |
Please help confirm a midi/delay comp bug | Kristo Kotkas | Pro Tools 10 | 6 | 06-25-2013 04:00 AM |
Can I do Multiple Midi takes then comp? | TheBaron | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 02-10-2010 02:46 PM |
Midi learn in PT 8 and bus delay comp | peter99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-18-2009 12:43 AM |
PSP Master comp, nearest plugin comp to Manley Vari MU? | crizdee | Pro Tools TDM Systems (Mac) | 1 | 05-22-2007 05:21 PM |
