A simple PC based PT10 system for post (only)?
We need to get a PT 10/CPTK native system working here (we otherwise use Brand-X mostly), and it needs to be on a PC, pref with 32 bit W7. At this point I have zero interest in building a PC myself for this, or dealing with someone who will build some special music/audio PC for me. I see that Avid specs a couple of current HP PCs for use w/ PT (Z400 for instance)--is there any reason why just buying one of these (with some extra drives and a triple head video card) wouldn't work ok? We don't need the badassest PT system that ever was, just something that will work for relatively simple long-form projects. Due to other apps we need to run (and don't wish to rebuy) the system needs to be a PC, not a Mac. I posted this here since this system will be used exclusively for post, no music work etc..
(Apologies for the crosspost to those who also read the GS post forum.) thanks for your thoughts phil p |
Re: A simple PC based PT10 system for post (only)?
We have many video edits on z400s here, I think the 6 core model. They are pretty powerful machines, and highly professional, don't see why they wouldn't be up to snuff. Only headache with pt on a pc is no blackmagic support but you already mentioned getting a triple head video card.
I've been running PCs for the last 6 years, and the higher spec'd z400 should do the trick for you. You should be able to add a 2nd dual head video card, as opposed to a triple head card - Triple head cards are expensive!
I was looking to upgrade to either a z400 or z800 in the last few weeks, but actually decided to go back to Mac - it's actually cheaper than a fully spec'd out z400, and it can run the blackmagic cards... hope that helps... |
PT10 any better for LASS and EWQL than the VST based systems? | Philee | Pro Tools 10 | 2 | 11-19-2012 05:27 AM |
HELP with simple shortcuts on PT10 | Riversound | Windows | 2 | 09-16-2012 04:25 PM |
PT10 HD system can't cope with session created in PT10 (LE) | LizS | Pro Tools 10 | 19 | 07-27-2012 03:46 PM |
Putting together an LE based post system, how do these specs look to you? | diamondschwin | Post - Surround - Video | 17 | 10-06-2009 07:19 AM |
Pricing a Simple Audio Post System. Tha turns out to be not so simple... | mazuroo | Post - Surround - Video | 1 | 05-30-2002 06:15 PM |
