Tape Backup
Any suggestions on a tape backup? Can you use compression with PT?
Thanks
JLE |
Re: Tape Backup
Yes exact tips on which box to tick or not to tick in Retrospect would be most apreciated! There is an option there I dont fully 'get'.
I use a DDS3 data dat BTW Option is: "data compression in software" (I dont have this ticked) I have verifacation ticked Jules [This message has been edited by Jules (edited June 10, 2000).] |
Re: Tape Backup
Hey Jules,
Im just researching some backup solutions for our studio at the moment. How do you find the tape system your using i.e. cost, performance, reliability etc? Would you recommend it?
Todays posting was brought to you by the letter e |
Re: Tape Backup
Yes, DDS 4 the best and very fast, no on compression, it's just too risky. price watch .com $1000.00 est.Sony SDT-1000. or SDT 11000 which is external.Select tape storage, I use mezzo 3.6.6. and it rocks. I have used Exibyte for years, it's just too slow but stable.
Later, Kurt [email protected] Intel duel Quad core PT 8.0cs3 HD4 D Command / D control |
Re: Tape Backup
I've used Mezzo w/DDS-3 for 18 mo. with no troubles (knock wood…). If I were buying today I'd go for DDS-4… better speed, capacity, etc. Highly recommended for frequent backup/restore/remix situations! I always have Mezzo set to full verification & NEVER use data compression… tapes are cheap enough that compression simply isn't worth the risk. Also, I've yet to have a client object to paying for the tapes… a data tape is media just as a roll of 2" analog tape is, which I'm certainly not going to supply! They're very happy to know that a recall is easily done if they should change their minds about mix details, lyric changes, etc.
Warmest Regards, Brian |
Re: Tape Backup
AIT II. 20 Gig backup. It's not cheap, but very fast.
Re: Tape Backup
DLT IV 40 gig native (uncompressed) with retrospect software.
fast, reliable and prices are falling on tape media. 300 mb per min transfers are possible depending on your system (drives and buss speeds). Glenn
Glennbrn |
Re: Tape Backup
Just my 2 cents, get a big tape backup unit so you don't have to change tapes and wait around. Retrospec seems to work just fine for me, but you will need the Special Drivers Kit Ad-on ($170) for most of the larger tape drives.
You will often find the Sony AIT(or Seagate, actually Sony) SCSI drives on eBay new for well under $1000. With the newest firmware and the newer 230 meter tapes, these drivers will do 35gig uncompressed. However I do use compression, in my opinion a backup strategy that works for a data server will certainly work just fine for audio. I strongly recommend running verification as part of the backup script. It does add a lot of time but if your backups are unattended who cares. Also spend some money on tapes and circulate tapes so you have a number of separate backup sets for each project. Keep a backup log and cycle through the tapes as you go. . .while always knowing which has the latest audio etc. . .
...for system configuration info see my profile (Click on member name) |
Re: Tape Backup
I have an Eliant 820 8mm backup. Its Rock solid. However it is slow and expensive. Most major studios seem to be using this format with success.
Re: Tape Backup
<BLOCKQUOTE><font size="1" face="Arial,Helvetica,sans-serif">quote:<HR>Originally posted by BDWillis:
I've used Mezzo w/DDS-3 for 18 mo. with no troubles (knock wood…). If I were buying today I'd go for DDS-4… better speed, capacity, etc. Highly recommended for frequent backup/restore/remix situations! I always have Mezzo set to full verification & NEVER use data compression… tapes are cheap enough that compression simply isn't worth the risk. Also, I've yet to have a client object to paying for the tapes… a data tape is media just as a roll of 2" analog tape is, which I'm certainly not going to supply! They're very happy to know that a recall is easily done if they should change their minds about mix details, lyric changes, etc. Warmest Regards, Brian<HR></BLOCKQUOTE> FWIW, on most DDS drives, the hardware compression defaults to "on" anyway....you might be using compression and not be aware of it. If the drive defaults to "on", it will compress, regardless of what you tell Mezzo to do. Really nothing to worry about. It's especially good if you have lots of quiet or silent passages. With really loud stuff, it doesn't really compress that much. I found that with Mezzo, verification is actually FASTER with "full verify" than "partial", at least with DDS-2. dc |
LTO tape backup | fdc | Storage Subsystems | 2 | 07-20-2005 04:02 PM |
TRAVAN Tape Backup - compress audio backup or not ? | stoneinapond | Pro Tools TDM Systems (Mac) | 2 | 11-28-2001 12:35 AM |
Backup - Tape or MOD | Raven | Pro Tools TDM Systems (Mac) | 1 | 07-31-2001 01:55 AM |
is anybody using VXA tape backup? | Anibal | Tips & Tricks | 1 | 08-03-2000 12:24 AM |
Is anybody using VXA tape for backup? | Anibal | Tips & Tricks | 1 | 03-18-2000 10:48 AM |
