Old 09-01-1998, 06:16 AM
Bernhard Maisch Bernhard Maisch is offline
Default Import DD8-PT-AV
The AKAI DD8 (V.2.0) creates Protools Sessions, which ca be used with PT 4.0, but Audiovision fails to Import them.
Is there another Way from DD8 to AV ???
Old 09-01-1998, 09:48 AM
DigiTechSupt's Avatar
Default Re: Import DD8-PT-AV
I'm not familiar with the DD8 or it's ability to create Pro Tools session documents.
If Pro Tools, is able to see and open the Pro Tools session documents created by the DD8, try opening them in Pro Tools first, save a copy of the session and then try importing the copy into AudioVision. The copy will bave been created by Pro Tools as opposed to the DD8 and should work.
Thanks,
Jon Connolly
Avid Audio Tech Support
Support FAQ
Old 09-05-1998, 12:41 AM
sorry, I´ve tried this way, (also savin as PT3.2 for AV3.6), it does not help
HTML code is On
Does "Automatically Copy Files on Import" work with Import Audio command? leftalive Pro Tools 10 3 04-17-2013 09:35 PM
Import Session Data with out Audio import disinfor Pro Tools M-Powered (Mac) 7 11-14-2010 11:44 AM
Import Audio search window results will not import BA Studios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-25-2008 09:00 AM
Import track color in import session data deardaddy Pro Tools TDM Systems (Mac) 5 06-11-2007 06:35 PM
Re: Import Audio or Bounce to Disk then Import filosofem 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-10-2005 03:52 PM
