Old 11-27-2020, 09:52 AM
johnbarnesiii johnbarnesiii is offline
Default MOTU 828 MKIII - Mac Compatibility
Hi guys,
I’ve been running PT 12.5 on an older MacBook Pro (late 2011) using the MOTU 828 MKIII as interface. Now I need to upgrade my MBP due to a logic board problem, so I’m wondering...
which MAcBook Pro models will be compatible with the 828 MKIII? Is it only the ones with FireWire and USB 2.0 ports, or will the newer Macs work too if I used adapters (ie FireWire to lightning or usb 3.0)?
Just want to make sure the newer Mac I get will recognize the 828 MKIII.
Thanks for any tips!
Old 11-27-2020, 11:38 AM
ChuckS ChuckS is offline
Default Re: MOTU 828 MKIII - Mac Compatibility
Something like this: Apple Thunderbolt 3 (USB-C) to Thunderbolt 2 adapter with an Apple Thunderbolt 2 to firewire adapter. There are plenty of threads out there about using older FW devices.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 11-28-2020, 04:32 AM
Originally Posted by johnbarnesiii View Post
Hi guys,
Connecting your 828 is only part of the problem. Make sure the drivers for it are compatible for whatever OSX (or Big Sur) comes on the new machine. I just checked on the MOTU site and as of right now they're not announcing compatibility with BS although we're told that is being worked on with Apple.
PT 12.5: Inputting bass signal into MOTU 828 mkiii johnbarnesiii Pro Tools 12 4 07-19-2018 03:06 AM
useable inputs using a motu 828 mkiii skwad Windows 4 02-05-2013 07:33 AM
MOTU compatibility with PT9 alithomas66 Pro Tools M-Powered (Mac) 5 10-25-2011 06:59 PM
New MOTU 2408 MKIII for trade DigiMixStudios 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-17-2003 05:37 PM
Motu Compatibility with PT sukks2bu General Discussion 3 06-24-2001 07:03 AM
