Old 01-11-2021, 03:34 AM
lode lode is online now
Default Simple ASIO USB sound card that can output AC3
I'm stuck at home working, and am looking into a way to use my home theatre for simple editing.
It does not unfortunately have 5.1 analog inputs. Only HDMI or optical/ electrical AC3 for surround.
A simple ASIO USB sound card that can make an AC3 stream would work.
Does anyone have a suggestion?
Newest Pro Tools on mac & pc.
Old 01-11-2021, 07:31 AM
quadraphonics quadraphonics is offline
Default Re: Simple ASIO USB sound card that can output AC3
I have output encoded AC-3 over the optical outs on a Mac Pro...
Randall
Randall Smith
Audio Editor/Mixer
Starz Entertainment Group
Denver, CO
Old 01-11-2021, 01:11 PM
ok. So you set up the mac audio driver to send 5.1?
Never seen that done.
I am on pc, and I tried, but couldn't figure out how to tell the driver that it should out put more than two channels. Any way, the motherboard only would then give analog out, so that wouldn't be of much help.
So I am looking for a simple USB card that plays nice with PT.
Old 01-12-2021, 01:20 AM
Top Jimmy's Avatar
You’ll need an ac3 encoder running as a plugin in Pro Tools to output ac3 format.
https://neyrinck.com/soundcode/sound...lby-digital-2/
James Cadwallader
Old 01-12-2021, 02:01 AM
fresler fresler is offline
One of my setups is just like what you are describing.
I'm running my Mac via HDMI to a Yamaha receiver with no audio interface in between.
If you are on a Mac it's a fairly straight forward configuration, in Utilities open Audio Midi Setup and switch your HDMI out from 2 to 8 (or 6 depending on your receiver). Pretty useful for testing mixes on a consumer/home setup.
Luca de Sensi
Old 01-12-2021, 02:25 AM
Farhoof's Avatar
Farhoof Farhoof is offline
I have used a Decklink for HDMI multichannel output. No need to encode AC3 or decode. Bonus: it will output your video as well. This was on a Macbook, think it was the Thunderbolt box. I had to swap C and LFE (in PT) due to a different HDMI standard but other than that it was working fine.
HTML code is On
Installing PT10 without ASIO sound card present. jimexplore Windows 2 06-01-2012 02:45 AM
2nd ASIO Sound Card? jermz16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-23-2008 04:16 PM
Using computer sound card as PT output MisterMacksta 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-06-2007 03:09 AM
ASIO. sound card. thr0ttles 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-21-2003 12:42 AM
Which sound card to use for Asio along with TDM? ozinga Tips & Tricks 0 06-24-2000 01:12 AM
