PT10: Lockup when un-grouping large clip-groups?
anyone getting beach balls of death when ungrouping large clip-groups in PT10? I get this all the time. Brings up bad memories of PT7.4 that crashed all the time when undoing region-group trims after complex re-cuts. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: PT10: Lockup when un-grouping large clip-groups?
Yep. You're probably out of memory. Before doing complex region group stuff I would try quitting and relaunching Pro Tools and also setting the undo queue to maybe 1 or 2 undos.
We've gotten in the habit of keeping our eye on the "VSIZE" in Terminal. Helps a lot... dc |
hm. not really. disk-caching is off. Undo level is set to 1. I always do that when conformalizing. A habit from working on 7.4
Plenty of RAM left BTW.
So I have 12GB RAM now. But it doesn't make a difference. Disk cache on or off doesn't make a difference either.
I´m on my 10th reboot while trying to trim regions groups after a re-cut and I have about 60 groups to go. It seems even worse than under 7.4 on my old G5. Undo level is set to 1. I have about 11GB free memory when this happens and the session is still rather light as I have just started working. If this goes on I´ll be working a week on the trims only. Really frustrating.
Sorry,
but I have to point out again how annoying this is. In my current re-cut PT will lockup even when I make a selection inside a clip-group and hit C. It seems to be worse than it ever was under PT7 (on a G5 with 6GB RAM!!) I have 12GB free memory out of 16GB when this happens. Have tried all sorts of combinations of settings. Currently disk-cache is off, undo-level is set to 1 and it happens every 2-3 edits. Sometimes even on the very first edit-operation after a complete re-boot. It slows my workflow down to a crawl.. Please fix. Thanks, Frank.
If I'm conforming with clip groups I tend to ungroup chunks I've finished editing after several cuts otherwise I get beachball lockup for about 30 seconds. Try minimizing the quantity of large groups you leave on the timeline.
This is on Mac Pro, 6GB ram, disk cache maxed. -Justin
Justin Walker |
On my system the lockups only happen on trims and copy/paste operations. Ungrouping works fine. Strangely the lockups never happen when it´s conformalizing. Only when hand-editing.
Region Groups-->Clip Groups Import File Menu Not working | minister | Pro Tools 11 | 0 | 01-06-2014 11:23 AM |
Clip gain on clip groups: bug or feature? | idris | Post - Surround - Video | 6 | 01-02-2013 10:48 PM |
clip groups question/problem? | capt kirk | Pro Tools 10 | 1 | 11-01-2012 02:36 PM |
conforms with large region groups | FilterDecay | Pro Tools 10 | 5 | 01-11-2012 03:57 PM |
Clip Gain Needs To Follow Groups | DougBull | Pro Tools 10 | 3 | 11-18-2011 03:46 AM |
