New Eleven Rack Track: "Bonneville"
I already posted this on the Eleven Rack User group so sorry if you've already read this. However, if you're not on the 11R user group forum then you should be!....
Here's a rough mix of a track I've been working on for a while. It's finally in some sort of finished state (kind of...) It's a pretty amorphous sort of format...just an excuse for lots of guitars and effects and trying out different ideas really. Hope you like it! http://soundcloud.com/jimification/b...e-jimification Signal chain is a Les Paul into the Eleven into Ableton. I mostly used the plexi model and some of the XTC red channel. Lots effects - phase 90 and flanger models (often at the same time) too as well as memory man and ping pong delays. Any crits are welcome. I'm a bit blunted by listening to it so much, so any feedback (good or bad) would be great. Thanks. |
Re: New Eleven Rack Track: "Bonneville"
EXCELLENT Dude!
I enjoyed the journey. Great playing and not a bad mix either...my only constructive criticism is that the drums aren't quite in the pocket and could do with a touch of reverb, perhaps the hat pulled back a tad IMHO. Nevertheless you should be proud of that effort man...well done Edit: I've listened to it several times and like it better each time!
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Thanks Zedhed. That's good critique about the drums...I had another listen after reading your comments and I definitely agree that I could polish them up a bit (both sound and tightness wise) and a bit of reverb is a good idea. Someone else also mentioned the high-hat so that certainly needs taking a look at too.
I'm really glad you enjoyed it. Thanks for listening and for the encouragement and valuable feedback. |
Solution to "Track could not be record-enabled" issue with PT10 and Eleven Rack | spankyq | Pro Tools 10 | 8 | 04-20-2015 08:19 AM |
Eleven rack expansion pack serial "already activated" | pieroft | Eleven Rack | 31 | 12-30-2011 04:37 PM |
Eleven rack (11R) slow booting past "setting up midi" | Edleigh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-25-2011 09:44 PM |
"Eleven Rack" window gone in PTLE after upgrading to Lion? | Deny | Eleven Rack | 6 | 10-03-2011 07:23 PM |
Do I need the "Transfer Ownership Audio" form to sell my Eleven Rack? | acmost | General Discussion | 5 | 04-16-2011 12:07 AM |
