Why am i getting 100% CPU usage using pro tools 8? How do I fix it?
When I open up a session(session1) that has 4 audio tracks and 2 MIDI tracks on PT8, the CPU usage goes to 100% and does not play back at all. Although, when I open up another session(session2) with 5 audio tracks the CPU usage is at around 15%-25% and runs smoothly.
On Session 1 i have eleven free on 4 of the audio tracks, and BFD and Xpand2 on the MIDI tracks. On Session 2 i have no plug ins I've done all the optimizations in the setup guide and closed all other applications. How do I bring down the CPU usage or fix the problem of the session not playing back by still keeping my tracks and plugins? Windows XP Professional Pentium 4 CPU 2.80GHz 2.79 GHz 2 GB RAM MBOX 2 500 GB 7200rpm external hard drive Pro Tools 8 |
Re: Why am i getting 100% CPU usage using pro tools 8? How do I fix it?
THAIR IS YOUR PROBLEM. GET A MAC |
Yeah get a mac or at least a lot more memory (4-8GB), and a dual / quad core system.
Mac 8 core 2.8GHZ 4GB RAM, 4TB Disk, OS X 10.6.2 HD1 core card, 192 i/o, behringer ADA 8000 mic pre, symetrix sx202 mic pre, Behringer studio monitors, tascam cd-a500, SM58, Blue Baby Bottle,Samson co2, M-audio Keystation pro, |
Nice answers, guys!
What is your Hardware buffer size? Eleven Free is a huge CPU hog, so it will always be a tradeoff between latency and the amount of real time instances that you can use. Xpand 2 is also no slouch when it comes to CPU usage. I think you'll either need to use one instance of Eleven at time and "print" the effect to the track afterwards, or set your hardware buffer to the highest setting and deal with the latency. Depending on what library you are using with Structure, I don't know if adding more memory will necessarily help, but it's a cheap solution and it definitely can't hurt. |
LOL you don't need a mac, CPU wise there is little difference anymore.
On a p4 that doesnt even matter...
To the OP, Dont waste the extra money getting a mac though although if u wana run like that u definitely need a new system... Grab a i7 rig or @ least a quad... Search/check in those particular threads for specs if u plan on actually upgrading ur system...
Pro Tools 10 CPU usage help? | Travis1290 | Pro Tools 10 | 1 | 01-31-2013 07:07 AM |
online usage and pro tools | jamiet | macOS | 1 | 06-25-2011 11:05 PM |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
Ram usage with Mac OSX Pro Tools 7.2 | Digiboy cs1 | Tips & Tricks | 1 | 10-02-2006 06:25 PM |
CPU Usage 100% when running Pro Tools LE | Mason00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 06-27-2005 12:50 PM |
