macOS Dual monitors not keeping configuration
I don't know if this has been addressed, but lately PT20 does not start up the way I quit it. The edit window in one monitor, and the mix window in the 2nd monitor. This just started happening lately. I don't know if it's due to Mojave, or PT20.5
Is there a workaround for this?
Music is the Message |
Re: MacOs Dual monitors not keeping configuration
Never mind, I found the solution in another post, by Googling the question.
I am having a similar problem, not sure if exact, but similar. Would you please share a link to your solution.
Blah blah blah....grumble grumble....woo hoo woo hoo.....dig it? |
Sadly, a very common thing on forums; people post: I've solved it, nevermind. Forgetting that half the point is to share the solutions.
I think PT is very lacking in this window management department, but one thing that often comes up as a workaround is to not use full-screen on the PT windows, but to just resize them to fit the display. IHTH.
Mac mini M2 16GB RAM macOS 13.4.1. PT Studio 2023.6. Topping E30 II DAC, Dynaudio BM6, 2 x Artist Mix, SSL UC1, Control on iPad. |
I had the same problem and this is what fixed it: Resize the edit and mix windows to be slightly smaller than your monitors background. You need to be able to see a small outline of your desktop background around the ProTools edit and mix windows.
Dave Pro Tools Ultimate 2022.12 / OSX Monterey 12.6.2 Avid HD Omni / HD IO 8x8x8 / HDX Sonnet Echo Express 3 iMac Pro 3GHz, 10 Core, 64 GB |
Or make it quite a bit smaller, then Option-Click the green button at the top left of the window. It should reopen to that same size - works for me at least.
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (2) TC Electronic Studio Konnekt 48 Avid Artist Mix/Control Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
On my OS it put my monitors in Full screen mode.
It what ?, when you hold option and then click the green button it puts it into full size, not full screen mode. When you just click the green button , without first holding down option , it will then put them into full screen mode , At least that is how it works on my system ..
. Again Either size manually smaller than full l size, or as cwsand mentioned "Option" then click the green button
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4 Enjoy the Journey.... Kev... |
Pro Tools tabbed windows in MacOs - Windows configuration not working | hugocentrique | macOS | 3 | 11-06-2023 05:26 AM |
Best Mac mini 2014, Pro Tools and macOS configuration | jackemski | Pro Tools | 1 | 01-21-2022 10:42 AM |
Configuration window on 2 monitors issue | mnstudio | macOS | 3 | 07-28-2021 12:28 AM |
Dual monitors: Can I have my mix and edit windows on different monitors? | songwritersoul | Pro Tools HDX & HD Native Systems (Win) | 5 | 05-23-2014 11:16 AM |
Windows configuration probs when across 2 monitors | crizdee | Pro Tools TDM Systems (Mac) | 0 | 12-11-2006 07:30 AM |
