Old 04-30-2016, 09:57 AM
albee1952 albee1952 is online now
Default Re: Plug-in changes sample rate?
Step #1-open a support ticket with Waves as they need to know any and all that are having this issue. I agree with the others about it being a cpu hit and nothing to do with sample rate.
Step #2-until Waves comes up with a solution(and I do think this is a waves problem, not a PT problem), I would stop using the plugin. As with most VI synths, there are several that can arrive at essentially the same sound, so maybe experiment with others that you have, or try some demo's from other makers.
Old 05-04-2016, 06:39 AM
gyiakoumi gyiakoumi is offline
Hi
Thanks for reviving this thread as it's still causing issues, glad to see I'm not the only one... I did open a ticket with them last night and they told me
Dear George,
Thank you for contacting Waves Tech-Support,
Please note that Elements 2 is very CPU demanding plugin which in heavy sessions can cause CPU spikes.
I suggest that you try to disable any other high demanding plugins and/or raise the buffer size in ProTool's PlayBack Engine preferences.
Also I suggest to change to Elements 1 algorithm mode in order to reduce CPU consumption.
You may also try to reduce the number of Polyphony/Voices
Let me know if you need anything else.
Best Regards,
Waves
I'm gonna go back to them later after work as I don't really see this a solution at all, if it's high in CPU then they should make it not so. and tbh it isn't, not really... like I reported it is high in CPU when loading, once it's loaded it's fine.
I just bought Native Instruments Komplete 10 Ultimate the other day and if I don't get this fixed i'm just gonna uninstall it and use one of the several synths included in that package instead.
Thanks
George
Old 05-04-2016, 08:38 AM
Originally Posted by gyiakoumi View Post
Hi
Thanks
George
Do a couple of things BEFORE you try using any of the vi's in K10 inside PT. First, after you install and authorize the plugins, run NI Service Center to make sure you have all the latest updates as what's on the hard drive you get are NOT the latest version. Next open each vi in standalone mode first, make any preference changes, close the vi. They should then be good to go in PT or whatever daw you're using.
Jack
QAPLA!
Old 05-05-2016, 12:42 AM
Thanks for the tips musicman691 :) They're all up to date now.
Hopefully an easy one for you guys: Opening 8 KHz sample rate / 16 bit sample size sample Pro Tools 11 2 02-24-2016 01:04 PM
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up finalcut Windows 12 02-20-2012 04:00 AM
Bit Rate / Sample rate supersam83 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2010 08:55 PM
MBox Micro Sample Max Sample Rate Only 48 kHz? Joe Sciacca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-07-2008 12:52 PM
Bit Rate/Sample Rate problem? The chipmunks? bspro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-17-2008 05:40 PM
