The missing point...
Ok, just for fun... got a simple question: What is the PT function you never ever use?...
like, for example...one of them for me is the "go to the end of the song" button on the transport window. I never use it... I don't even care about it. maybe I'm missing something here? |
Re: The missing point...
I never use sync points. (Though I probably should)
----I was thinking of taking a solo in the bridge. -Nah, I don't think that would sound good. ----Ok, well how about just a series of cool riffs? Mac Pro 2008 (Harpertown) -- OS X 10.8.2 -- 16GB RAM -- WD Black Drives -- UA Apollo Quad -- Pro Tools 10 w/ CPTK |
I never use ADC...
MBox2Pro / LE 8.0.5 |
bounce to disk
i7-860 / 12GB Kingston / Intel DP55WB / 500GB Barracuda / 1TB Deskstar W7x64 Focusrite Saffire Pro 40 / Pro Tools 9.0.3 Mics, Guitars, Amps, Basses, Drums, Keys http://overtheeffect.bandcamp.com |
@ barstool, True, in all fairness I've never had an issue with the lack of ADC, except for a slight phasing on parallel processing maybe, but as you mentioned, easily sorted with time adjuster. @ the OP, I've never needed to use the scrubber.
what do you use instead of Bounce to Disk? Record to a separate track?
iMac i5 Quad Core 27" 8 Gigs Ram / 1T internal HD Lion 10.8.2 2X - 1T External HD with Mercury Elite Pro Enclosure MBox 3 Mini ProTools Express 10.3.3 The Final Lap http://thefinallap.com |
Never had a problem with Bounce to Disk since 6.1.1. Embarrassed to say I never use Beat Detective as I just can't figure it out(thank God for EA)).
yep. always. i route everything to a "mix" aux, and then bus that to a new audio track and sometimes will make little fader moves on it (ie a harder part of a song, give it a little bump - adds some more life IMO) and then just use export file as region. just got to be habit, and i stuck with it.
How do Insert an in point and out point in my tracks and play this as a loop. | scottee | Windows | 2 | 08-15-2012 08:08 AM |
Fixed Point vs. Floating Point | Oblivion777 | Pro Tools 10 | 19 | 12-15-2011 06:46 AM |
Missing fade files, missing audio in resaved sesssions | drygruo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-14-2010 04:56 PM |
Floating Point/ Fixed Point/ Dither | Nika | Tips & Tricks | 2 | 02-15-2005 12:05 PM |
Snap sync point to sync point? | imi | Tips & Tricks | 3 | 05-25-2003 06:48 AM |
