Pro tools HD II and Xserve
Hi all,
I'm going to record live session with my HD II. I like to know if the Pro Tools HD is compatible with the Xserve (intel) I want to put it in a Rack (more easy to carrying than the Mac pro) Did someone use HD PT in a Xserve ? Thanks ByPass |
Re: Pro tools HD II and Xserve
Keep in mind that Xserve is *longer* than standard audio racks. Much longer! I think usually audio rack is 45cm deep, but computer racks are something like 70cm deep beasts. So it's not that easy to carry around. At least I prefer the desktop workstation that has nice handles.
AFAIK, it is not possible, as the OS X for servers is different from the OS X for ordinary Macs.
I once asked, because I had the same idea, but sadly it was (at least at that time) not possible. matthias
MacPro 7.1 8c 3.5 GHz, 48GB RAM, HD native PT 2021.12.0, 10.15.7 www.imdb.com/name/nm0501611/ |
Is there a reason why you couldn't install OSX Client to a server hardware? I think not. And as far as I know, OSX Server is just a superset of OSX Client (or to put it another way: OSX Client is a subset of OSX Server). The same core, the same drivers. I don't see why you couldn't make it work, software-wise.
But the hardware is *DEEP* when you look at it in the real life. Picture tells a thousand lies in this case.
I have a few Xserve's, they should be able to run the normal desktop Mac OS X just fine. As everyone said, the xserves are very long, I use an an Xrack:
http://www.xrackpro.com/xrackpro2a.htm Which blocks a lot of the sound out... |
the xserve also emit a lot of noise..
think a small vacuum cleaner, turned on... all the time.. WHHRRRRRRRRRRRRRRRRR ZOOOOoOOoOoooMMMMMmMmmMMmmMMMMMmmmMmm VIIBRRRAATTTEEEEE it's server class, its loud and robust. |
also the xserver has limited slots.. depending on the model you get.
i have a new intel one across the room from me right now.. i can hear it.. |
what I'd like to know is if you're using OSX client and Pro Tools work, can you use the Pci-X slot for a pre-pcie HD1 set-up?
"The secret in life is to have no fear" Fela Anikulapo Kuti |
Xserve Compatibility with Pro Tools 8 ? | Matt Darcy | macOS | 6 | 09-03-2013 01:36 PM |
xServe and Pro Tools 002 with 7.0 LE software | freqonavitch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-30-2005 01:43 PM |
pro tools hd compatible with xserve g5? | DiscoD | Pro Tools TDM Systems (Mac) | 2 | 11-02-2005 05:23 PM |
Pro Tools TDM with Xserve RAID | paraprod | Pro Tools TDM Systems (Mac) | 11 | 11-05-2004 09:09 AM |
A new XServe for Pro Tools 6.0? | polnetwork.com | Pro Tools TDM Systems (Mac) | 5 | 02-14-2003 06:51 PM |
