Creating a multichannel BWAV file
I need to convert 5 mono stems into a single embedded multichannel BWAV file with timecode metadata. Can protools do this, or do I need something like WaveAgent or SoundGrinder perhaps?
Re: Creating a multichannel BWAV file
Just put the five mono stems onto a 5.0 track. Place the file at the time code you want it to start at. Consolidate the file which will embed the time code. Re label the file and export as interleaved. If the file size is over four gigs it won't let you do this as pro tools is limited to four gigs per wav file ( is this still true?) . In which case you can either go multi mono or use a different piece of software.
Final Cut Pro as well
NuanceTone.com |
Do the same procedure as far as the consolidate. Then select the 5.0 track and "split to mono" from the menu ( can't remember which one, third from left I think). Then re label each mono element and then select all six files and move them back onto the 5.0 track and export!. I think this should work for you. |
Look at WaveAgent from Sound Devices. It's free! |
For the multichannel file to work each mono stem must have the same name. Then add the suffix .A1, .A2 etc for each stem file. If you need to name the individual files DX, MX SFX etc then creating a multichannel file will not work because the the file names are different. (You could use the metadata option to identify each component within the multichannel file just to avoid confusion).
2 cents
[email protected] Newcomer Audio Post MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock... |
Waveagent. Simple app yet the most effective for this task.
Wave Agent is very capable.
Be VERY careful using the time code stamping feature. You must test PT time stamping versus WA time stamping and see how it applies to your particular case. j mcd |
Creating 16/44.1 audio file | midnightsun | Pro Tools 11 | 6 | 12-23-2013 12:54 AM |
8.4 Creating Audio File Folder on another drive | hmac | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-11-2010 01:32 PM |
Problem Export or Bounce Long multichannel file | Xenon | Pro Tools TDM Systems (Mac) | 1 | 09-08-2008 11:23 PM |
creating .mov/mpeg4 file from dvd - other ways? | 1tonstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-09-2006 10:08 AM |
Program Error when creating new file | moosh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-24-2001 01:23 PM |
