Xpand2 playing wrong notes once recorded.
Ive had this strange issue happen a couple of times now and can't put my finger on it. Yesterday a band I was recording asked me to add in some midi trumpets. So I played the track and started playing my midi keyboard to record the notes I needed they all sounded in key, but when I played it back the notes were out of key and I had to move them all down a semi tone. This is the 2nd time I've noticed this when playing midi. This has totally confused me probably because I'm not a midi guru. If anybody here could shed some light on this or has to experienced this issue and can help me out it would be much appreciated :)
Raoul Crane
www.blaze-studios.co.uk PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis |
Re: Xpand2 playing wrong notes once recorded.
Probably something in your keyboard. Like transpose is turned on, but not for MIDI, or something like that.
Don't forget you can just record the AUDIO from your keyboard instead. Benny Blanco says he does that for all his productions. No MIDI at all. If you are just recording MIDI into a VI though in PT, I would check the settings on the VI. Some of the samplers like Structure have transposition options that would do what you describe.
DC-Choppah's Project Studio: ASUS PRIME Z390-A / Intel i7 rackmount PC Windows 10 home 64 bit Pro-Tools 11.3.1 AIR Instrument Expansion Pack v2 WAVES Platinum plugin bundle Tascam US-16x08 Interface 100% Analog real time monitoring 16x4 Yamaha 16 channel MG16XU Analog Monitor Mixer Yamaha MX-88 / Novation XiO keyboards Mackie 4-channel headphone amp Adam A8X monitors Blue / Shure, etc. microphones Estonia 6' 8" Parlor Grand Piano Yamaha Studio Drum kit https://www.dc-choppah.com/ |
Thanks DC-Choppah I've never messed with the keyboard that's why Im curious how this has just started happening it's only a 2 octave midi novation keyboard. Where will the transpose option be, is it in the Pro menu's anywhere ?
Raoul Crane
I have a Novation Xio synth and the transpose option is under the global menu.
Recording midi notes from Xpand2 arpeggiator? | Calon | Virtual Instruments | 1 | 06-07-2015 05:01 AM |
realistic Hi-hat 16th notes in xpand2 | bower.steven | Virtual Instruments | 1 | 07-30-2014 05:57 PM |
Virtual Instruments playing wrong notes | CarlDelain | macOS | 6 | 07-09-2014 12:59 PM |
Playing Reason with recorded midi notes | jamescampagnola | Pro Tools 10 | 1 | 11-26-2012 12:35 PM |
N.I. Komplete playing wrong notes in pro tools. | chagos | MIDI | 3 | 06-06-2004 11:14 PM |
