move HD3 with HDX and 192 with HD IO
I replace my HD3 with a HDX and 1 of my 192 with a HD IO 8x8x8
I'm on PT 10.3.10 OS 10.8.5 The out of HD IO are perfect The in of HD IO nothing comes in the DAW but well on the meter of the HD IO For the 192 connected as expansion peripheral The out are moved of one out or swap B 3-4 with B 5-6
[FONT="Comic Sans MS"][B][COLOR="SlateGray"]Mac Pro Dual 6 Core Intel Xeon @ 3.46 GHz, 48Go RAM, OS 10.8.5, HDX Protools HD 10.3.10 1 x HD I/O + 1 x 192 |
Re: move HD3 with HDX and 192 with HD IO
For troubleshooting, I would simplify a bit. Disconnect the 192 so only the HD IO is connected. You say the outputs are working? Open the IO setup>Input tab. Delete all the input paths. Then create 8 mono inputs and "connect" by the grid matrix to the 8 analog inputs and test just those inputs. If they work, then shut it all down and connect the 192(which can connect to the HD IO expansion port, or directly to the other port of the HDX card) and add only the 8 analog inputs(same as above on the HD IO). Remember to connect the Loop Sync BNC cables.
oups I've modified the input wirh 8 mono routed as useal via my neve summing, the VU in show signal but in PT not any of the 8 inputs are showed
WRONG AFTER RESTART IN IS SHOWING IN THE DAW CORRECTLY For the mismatch of output on the 192, it was a nightmare in the bus list in the IO setup menu Many thanks for you help
[FONT="Comic Sans MS"][B][COLOR="SlateGray"]Mac Pro Dual 6 Core Intel Xeon @ 3.46 GHz, 48Go RAM, OS 10.8.5, HDX Protools HD 10.3.10 1 x HD I/O + 1 x 192 Last edited by HiLoc; 02-13-2019 at 09:22 AM. Reason: Mistake |
Considering move to PT 11 | serstickman | Pro Tools 11 | 12 | 05-30-2014 09:56 AM |
Move the red diamond in the tempo bar in the edit window, only some tracks move | kingheartless | macOS | 2 | 02-21-2013 03:20 PM |
is it safe to move to move to SL | ilulilu888 | Pro Tools TDM Systems (Mac) | 10 | 12-05-2010 10:23 AM |
Can I move regions and have the underlying playlists move also? | smpkeys | Pro Tools TDM Systems (Mac) | 4 | 02-18-2010 07:30 AM |
