Old 10-05-2012, 11:08 AM
Jen H Jen H is offline
Default MIDI tracks are recording an unwanted instrument sound
This noob needs some help please!! My first MIDI track records beautifully using Pro Tools 7 LE, Digi 002, windows OS, and a YAMAHA DGX500 keyboard. However, when I record the 2nd track, I get additional notes of the first instrument on top of the desired instrument sound I'm intending to record on Track 2. For example, if my first track is a Piano sound, and my 2nd track is drums, the drum track ends up containing unwanted piano sounds on top of every note of the drums. After this happens, my YAMAHA keyboard itself also plays these unwanted dual sounds. If I turn my keyboard off and on again, it clears the problem and the keyboard notes sound true again (with no duplicate, dual instrument sounds), but I have not found a way to fix the Pro Tools recording issue. I should mention that this same exact system, set up, hardware, etc. worked beautifully for my about 5 years ago. I put it away for some time and I'm trying to get back into it now -- which required me to set up everything again from memory. Did I set something up wrong in terms of cables? Any help would be greatly appreciated!
Old 10-05-2012, 06:39 PM
Default Re: MIDI tracks are recording an unwanted instrument sound
Go to VIEW>Mix Window Show> and check the choice called "Instrument". Now go to the MIX window and scroll up to see the new row of boxes at the top of each strip. On your instrument tracks, you can make 2 choices that should clear up the problem. First, the Midi input device that feeds each track, and the destination of the midi(which plugin instrument you want to be played by that track's midi data). Good luck
Recording multiple Midi (instrument tracks) Bookerv12 Getting Started 9 02-08-2014 06:17 AM
Tracks picking up unwanted sound/effect?? shockcityrocker Pro Tools 9 7 04-18-2012 07:33 PM
2 instrument tracks each controlled by different MIDI input/instrument Midimax Pro Tools M-Powered (Win) 0 03-20-2012 03:10 PM
Unwanted Automation on Midi/Inst tracks when adding meter changes nanaandbump macOS 0 10-02-2011 05:08 PM
unwanted notes in instrument tracks Ged Lineham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-11-2006 03:54 AM
