Side-by-side configuration error
Good morning everyone:
After upgrading to PT 10.0.2 I get this error message when trying to start Pro Tools: "The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxtrace.exe tool for more detail." I googled for a solution and searched the forum as well, and tried the suggestions I found, but none of them worked (disks do not have errors). PT 10 used to work for me. I am on Windows 7 64 bit SP1, and have installed all the latest windows updates. Update: After uninstalling PT10 and reinstalling it, I get this error message: "The application was unable to start correctly (0xc0150002). Click OK to close the application." If anyone has any suggestions, I'd be grateful. PT was running fine, I feel like a damn fool for upgrading ... don't fix it if it ain't broke. |
Re: Side-by-side configuration error
Make all updates of ptools you'll be fine
I did is okay now If you have problems opening pt Instal http://answers.microsoft.com/en-us/w...c-07e085232ab6 Enviado desde mi iPhone
Jascha Koneffke flutist www.prodmusica.cl GA-X58A-UD3R[/ I7 950 RAM 24Gb corsair 1600 (3 sticks) 9-9-9-24 MAC MacBookPro i7 2,3 15" RAM 16gb PT 11.3 003 Rack MBox 3 Pro |
Thank you Jasha!
I uninstalled Pro Tools, and reinstalled PT9. Pro Tools 9 is working for me. I did notice that it did install to this directory: [root] \Program Files (x86)\Digidesign which, unless I am mistaken, is different from the subdirectory to which 10 was installed (Program Files (x86) \ Avid). I may be mistaken but I think I am pretty sure. I am going to upgrade to 10 again now and see where that takes me. |
Update: before installing PT10, I had to uninstall PT 9.
After rebooting, and reinstalling PT 10, I get the same error message "The application was unable to start correctly (0xc0150002). Click OK to close the application." Update 8:43 am: googling turns up old and irrelevant search results. One thing I tried (but which does not work either) is downloading and installing .NET Framework 4. |
Install al update
10.1.2 on win Mac until 10.1.3
Thanks Jasha. I just reinstalled the latest update (10.0.2), I am now back to the initial error message:
"The application has failed to start because its side-by-side configuration is incorrect. Please see the application event log or use the command-line sxtrace.exe tool for more detail." |
this is the latest http://duc.avid.com/showthread.php?t=320970
Thanks Jascha.
Yes, that is the update I just reinstalled. Still doesn't work. |
Did you install the file i told you in the link in the
post above I solved whith that when my PT 10.1.2 was not opening
PT10 and PT11 side by side over HD3 | s9dd | Windows | 8 | 02-11-2014 08:22 PM |
can I use the Mbox2 side to side to an Omega Lexicon?? | nastyartproduction | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-23-2010 06:46 PM |
side by side error message | johncm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-17-2009 02:43 PM |
Digi,Side by Side errors in event viewer with PT's HD 7.4? | x9blade | Pro Tools TDM Systems (Win) | 8 | 12-15-2007 11:19 AM |
Can 6.1 and 5.3 be installed side-by-side? | SSRJazz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-26-2003 04:58 PM |
