Old 12-27-2016, 09:26 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Fade delete bug. Fix update!
Bug that appeared in 12.6.1 is still in 12.7
Only happens to fade outs, when i select a section of a clip that has a fade out that i want to delete, it cuts the clip and shifts the same fade to that new end point.
Can only deleted the fade, if I select the fade only. Does not occur to fade ins.
3 different systems (Mac) PTHD
Anyone else?
UPDATE:
I filed a bug report, and received a case number, responding fix is in for PT12.7.1 !!!
IMDB
Old 12-27-2016, 11:52 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Fade delete bug.
My system is showing the same behavior though I'm not sure it's a bug. Why not just right-click and choose Delete Fades?
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2020.5
Old 12-28-2016, 07:58 AM
Fade out only, not fade in? Its a bug.
Thats 2 steps, delete fade before delete section of clip. Thats not how it was.
You should be able to click/drag highlight a section of a clip, along with the fade out and click delete. Not have your fade out get recreated.
IMDB
Old 12-28-2016, 03:22 PM
Polarbear066 Polarbear066 is offline
I'm getting the same thing too.
As a work around I use "s" to trim both the clip and fade but its still a nuisance.
MacPro 3.1, MacBookPro 2010, 24Gig RAM, OS 10.10.5
ProTools 12.6.1, MOTU Track16, MOTU Traveller,
MTP-AV, Yamaha O2R
Old 12-28-2016, 04:19 PM
volkgti90 volkgti90 is offline
Anyone else?
I posted a thread about this very bug when i first installed 12.6.1. I now have upgraded to 12.7 and the bug is gone for me. Not sure why its gone for me but still there for you. Sorry i couldn't be of help.
Old 12-29-2016, 10:13 AM
Its a bitch.
Video editors always butt clips, and they have an in and out fade.
I would highlight the part of both clips, delete, and highlight a new cross fade.
This makes life dificult.
IMDB
Old 12-29-2016, 12:24 PM
sleepingtiger sleepingtiger is offline
Have any of you had instances of AAE 9480 errors with this fade bug?
I just spent a couple of days making 30 and 60 second edits of tracks and ran into this error a bunch of times. It always happened after using Cut Time or Shuffle mode to remove a large chunk or time from a multi-track session. After an edit, playback would stop right before the edit point and the error would come up.
In my back-and-forth with support I let them know that I thought it was fade related and they confirmed that it was after analyzing the dlog file I submitted. I'm wondering if this is related to the bug described on this thread. So far support has not offered a solution other than a cumbersome workaround.
Pro Tools Ultimate 2020.3
Dell Precision T7400
32 gigs of RAM
Windows 10 Pro
HD Native PCIe
Lynx Aurora with LT-HD
Apogee
Mytek
Old 12-29-2016, 09:41 PM
AAE 9480 is a bad fade from an AAF import.
Delete all fades.
IMDB
Old 12-30-2016, 03:09 AM
Delete all fades.
Thanks for the response. Apparently AAE 9480 is triggered by something else as well since I'm not currently working with AAF imports. Good to know though.
32 gigs of RAM
Windows 10 Pro
HD Native PCIe
Apogee
Mytek
Old 12-30-2016, 06:27 AM
mixboy bob mixboy bob is offline
This has been driving me NUTS!! So basic, such a time-killer. Rather infuriating.
Rob Burrell
aka mixboy
http://www.robburrell.com
PTHD Ultimate 2019.12/2018 Mac Mini 3.2ghz 6-core i7/32GB RAM/Aja T-Tap/Akitio Thunder 3 Quad Mini with 4TB SSD drives/Focusrite 16Line/UAD-2 Octo PCIe in Sonnet chassis/32 Channel S1/Dock with (5) 2019 Amazon Fire HD 10 Tablets/XMON//11.1.4 Dolby Atmos Setup
Fade LENGTH as an option in Preferences>Default Fade Settings gwhatley Pro Tools 12 0 10-07-2016 04:08 PM
Ok to Delete Fade Files? mjslakeridge Windows 5 09-21-2015 01:16 PM
Delete fade question jzzdaniel1 Pro Tools TDM Systems (Mac) 1 09-22-2003 05:26 AM
When trying to delete any sound region or fade in kwarkot Pro Tools TDM Systems (Mac) 0 12-18-2002 02:18 AM
How do I delete missing fade files?!! neil conti 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 07-06-2002 12:36 AM
