Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 07-15-2011, 07:07 AM
alexruimy alexruimy is offline
Default matching tempos - help!!
so i'm trying to make a dj set at 120bpm. i'm bringing in various tracks but i don't know the tempos of these tracks. what would be the easiest way to detect the tempo and then warp each song to match the session tempo?
(xpost from ptle)
Old 07-15-2011, 08:13 AM
stevedemena stevedemena is offline
Default
(xpost from ptle)
I wonder if a program like Native Instruments "Traktor Pro" would be better suited to this task? It's specifically designed for this. Check it out.
Steve de Mena
Mac Pro Late 2013, 32GB 6 Core, 10.10.4, PT HD Native 12.1, Apollo Quad TB
MacBook Pro 15" Retina i7 - 16GB, PT HD (mixing only)
Old 07-15-2011, 08:24 AM
Default Re: matching tempos - help!!
thanks! yeah i've seen and played with traktor and it definitely does this, but i want to create this in pro tools. i'm not good enough yet with live controls. pro tools is so feature rich that i'm sure it can handle this, i just haven't been able to figure out how to make it work in a non-laborious way you know?
Old 07-15-2011, 12:53 PM
RegenerationMix RegenerationMix is offline
Hi, this is the easiest to use.
http://www.all8.com/tools/bpm.htm
just tap the tempo and it will give you the bpm of the original.
much easier and quicker than beat detective or Identify beat. I use this all the time. gets me the bpm and its right on. I have tried other stand alone tap tempo software and it didnt work well.
makes it very easy when using time shift.
Chris
http://www.youtube.com/user/RegenerationMix
http://soundcloud.com/regenerationmix
http://twitter.com/regenerationmix
MacBook Pro, 2.4GHZ, 16GB, Intel Core i7, Mac OS 10.9.1 128 SSD internal HD, 750 GB Internal HD, Pro Tools 10.3.8, Digidesign 003r, Waves 8.0, Final Cut Pro 7
Old 07-15-2011, 04:03 PM
flommer flommer is offline
(xpost from ptle)
Workspace will sometimes determine the correct tempo. You can also set an option that will import the new material to match the session tempo.
How well it detects the tempo varies a lot, though..
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 07-15-2011, 05:25 PM
thanks for the help guys :)
Need help matching different tempos lalalandguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-05-2009 11:08 PM
The Matching Criteria List and Matching Playlists EricWillhelm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-13-2009 01:35 PM
Determining tempos FrothyG Pro Tools TDM Systems (Mac) 6 05-05-2005 09:40 AM
match Tempos ModaRecords Pro Tools TDM Systems (Mac) 3 02-07-2005 05:03 PM
tempos over 300? mike connelly Pro Tools TDM Systems (Mac) 2 11-17-2000 11:56 AM
