Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 07-31-2008, 09:13 PM
mgarzag mgarzag is offline
Default pro tools + macbook + ext. hard drive HELP!!!
Hello everyone,
I will buy a macbook soon, 2.4ghz 4gb..
I also want an M-Audio firewire interface and use M-Audio Pro Tools.
Since the macbook only have 250gb of space, I'm planing to buy an external hard drive rive.
Here is where my question start. I will be recording direct to external hard drive that will be connected to the macbook via usb 2.0.....
instrument---interface---(firewire)---macbook---(usb)---external hardrive
will this work? will I have any problems when recording, editing or mixing?.. or is better to record to the macbook using the interface to firewire port... and then moving the files to the external hardrive to edit and mix using the firewire port... thing is that the macbook only has one firewire port..
I will only be recording one instrument at a time, and it will be a guitar, bass or vocals. I also planning to use Reason and some plug ins for other instrument..
I'm new to this stuff... the past years I made my songs using a boss digital recorder with a zip drive, but know I want a little upgrade that I can afford..
Thanks to all for reading
Old 08-01-2008, 01:33 AM
Mattafact Mattafact is offline
Default
Use an external firewire drive and daisy chain it with your interface. I plug my external into my 1814 and plug the 1814 into my mac. That's the only way it seems to work for me.
USB isnt up to recording for the most part.
Breakthru Recording
www.myspace.com/breakthrurecording
Old 08-01-2008, 03:53 AM
Default
thanks for the info
Old 08-01-2008, 06:14 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default
This really depends on how many tracks you're doing. I've had crashes from too much firewire traffic before! My preference is to use a MacBook Pro putting the interface on the built-in firewire port. I have a Firewire ExpressCard that plugs into the MBPro for my external FW drive. This GUARANTEES that the two devices are on separate FW busses.
BTW, this also happens on my G5. Just because it has multiple FW400 ports and a FW800 port doesn't mean they're on a separate buss. They are ALL SHARED. I also have a FW PCI card on my G5 for this very reason.
All traffic collisions ceased after widening the Firewire Freeway!!
Just an FYI...
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 08-01-2008, 08:26 AM
JrummerJ JrummerJ is offline
Default
This is pretty much your only option if you go with the macbook. And it is one of the reasons I went with the macbook pro, for the expresscard slot and getting fw devices on separate busses.
You should be ok, there are tons of people running their interfaces and external drive chained.
J
Old 08-01-2008, 09:53 AM
Yosemite Yosemite is offline
Default
I agree with the advice above. Plug a FW400 drive into the open port on your interface. There is more to it though. For the low down on Firewire drives and Pro Tools read this page:
http://www.digidesign.com/index.cfm?...4&itemid=23114
You'll see only drives of certain speeds and with certain chipsets are fully qualified.
Good luck!
Old 08-04-2008, 10:49 PM
Default
Thanks to all for the information, really appreciated
New Macbook Pro Hard Drive Questions dbcs General Discussion 14 07-22-2012 06:18 PM
hard drive for Mbox/MacBook Pro gregfrey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-28-2010 01:50 AM
External Hard Drive for Macbook and 003 Steve7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-22-2007 05:32 PM
mbox2pro on macbook-hard drive? dxcease 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 02-20-2007 06:53 AM
2nd hard drive IN macbook pro therecordinghouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-28-2006 03:55 PM
