Old 05-26-2012, 11:43 AM
jglunt2112 jglunt2112 is offline
Default 96khz
I have a Toshiba computer with Windows 7 64 bit OS. I'm using recently purchased Pro Tools MP9 and M-Audio Fast Track Pro. Both software & hardware are supposed to be able to record at 96khz according to their specs, but I can only find settings for 44.1 & 48. The M-Audio manual tells me to set the rate in the software settings. The Pro Tools manual says it follows the settings made in the hardware. Grrr. Does anybody know anything about this?
Old 06-01-2012, 12:02 AM
highpass highpass is offline
Default Re: 96khz
I also have the Fast Track Pro. The sampling frequency depends on how many in- and output channels you select. If you have installed the correct driver (and I guess you have), you can do this in the FTP properties on the "bandwidth"-tab. If you, for instance, select only 1 analog input, the 96kHz option will appear.
It's described in the manual.
Old 04-01-2015, 03:29 PM
colincolin1 colincolin1 is offline
Default Re: 96khz
hello i tried several times to get the 96khz for my recording but it wont come up as on this picture.. and i updated also pls assist
Old 04-01-2015, 04:27 PM
Default Re: 96khz
What that screen shot is showing is the IO buffer size, not the sample rate. Set that to somethign like 512 samples and leave it there until you get things working. It may be time to open the manual and have a read...
96kHz???????? KamilFX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 04-04-2007 07:43 PM
24/96khz with mix and 888/24 i/o taiazeez Pro Tools TDM Systems (Mac) 0 01-28-2006 05:16 AM
96khz on PT LE 6.7 nickster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-10-2005 03:20 AM
96khz Is it necessary? Sharritan Tips & Tricks 10 10-03-2004 02:10 AM
From 96Khz to CD Compression Records Tips & Tricks 1 09-07-2000 07:51 PM
