Old 02-09-2010, 09:26 PM
Shatzer Shatzer is offline
Question Midi notes double
For some reason every time i record with my Axiom 49 into Pro Tools every single note is doubled. For instance, i hit a key and everything sounds fine, but when i playback and look in the MIDI EDITOR there is actually two notes. One is the note i played which is the longest one, and the doubled note is a very tiny tiny note that looks like an x inside the bubbled midi note. This does it with every note i press. Only in Pro Tools. I cant quantize because it throws everything off. I have to go in, slide each note i want to keep over and delete the "bad" note underneath it. Yes, it doubles but starts at the same exact time as the "good" note.
Any thought on whats going on?
Old 02-10-2010, 12:51 PM
YoRugMan YoRugMan is offline
Default Re: Midi notes double
Someone else asked about this recently - I think someone suggested that it's got to do with the recording of SYSEX data while you're performing.
There's a setting somewhere to switch this off.
"Well, of course, their requests for subsidies was not Paraguayan in and of it is as it were the United States government would never have if the president, our president, had not and as far as I know thats the way it will always be. Is that clear?"- Chevy Chase, Spies Like Us.
Old 02-10-2010, 12:54 PM
.... here's the thread :
http://duc.digidesign.com/showthread...72#post1550672
Old 02-10-2010, 01:06 PM
DigiTechSupt's Avatar
This could be a couple things.
Check your 'Default MIDI Thru Instrument' in Preferences>MIDI - try changing it to something else.
Make sure you don't have more than 1 zone enabled causing the keyboard to send more than 1 note out simultaneously. You can test this by limiting the input tab of the track you're recording to to a specific device and MIDI channel.
Make sure you don't have MIDI echo enabled.
Avid Audio Tech Support
Support FAQ
Old 02-10-2010, 01:15 PM
You mean instead of having the input set to the default "All" ?
Old 02-10-2010, 04:04 PM
It seems that (when using the mini grand) if i assign it to channel 1, i only get the first half of the keyboard and if i assign it to channel 3 i only get the second half. I only get doubled notes when using the "ALL" but i cant use the whole keyboard if i assign it to 1 or 3. I think it might be some settings in the Axiom 49 thats causing this and not PT. I'm going to try to reset it and see what i can do by messing around with some more settings.
Old 02-10-2010, 05:22 PM
Ok, FIXED. I reset the Axiom 49 by holding the - and + on the numeric pad while powering on and i'm not getting the doubled notes anymore even leaving the midi channel on to "ALL".
But now i'm having trouble using the transport controls in Pro Tools. I set it up the same way i did before and it use to work. I pressed the recall button and selected 15, and made sure the midi slave was enabled in preferences. I can't get the play, record, stop, rewind and fastforward to work like it was.
Old 03-20-2015, 04:30 PM
David.Straley David.Straley is offline
Hi All - I know my reply is late; I just joined today.
I have this same problems with my Axiom 61 controller, using Pro Tools 11.x.
I don't have a solution which prevents the double notes from happening in the first place.
However, there appears to be a workaround for "cleaning up your MIDI track" once you've recorded and gotten the double notes. It's this:
Select the whole MIDI track. Now click in the menu : Event -> Remove Duplicate Notes
That should do the trick.
Kind Regards and God bless
> DITW 1) Midi double notes 2) PT 8 stole my iLok key GrooveJungle Pro Tools TDM Systems (Mac) 3 02-26-2009 12:13 PM
Deleting MIDI double notes... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-17-2006 07:07 AM
Quantize: causing double midi notes; phasing??? gollywillickers 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 08-23-2005 10:39 AM
Underlying double Midi notes/data ? steals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-07-2003 12:47 AM
MIDI double notes on everything writethis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-27-2002 10:37 AM
