Drivers to Mbox 2 Mini and Windows 7, 64 bit
Hello!
I just uppgrade my computer to Windows 7 (64 bit) and i trying to get my Mbox 2 mini working. When i bought the mbox for a couple of years ago i got Pro Tools LE 7 on a disc. But that one dosen't work for Windows 7. And i don't care if I ever get that Pro Tools to work on Windows 7. I just want my Mbox 2 mini to work So i at lest can use my equipment.... I been trying to find a driver for it but can't find anything... Please help me! |
Re: Drivers to Mbox 2 Mini and Windows 7, 64 bit
okey... I checked if i could download a version of pro tools 8... and i got "Digidesign Audio Drivers Setup (x64)".... :\ I installed that and got some problem with some Intel driver (tpkd i think it was called). But just have to download a new driver and rebot. Now my mbox works but when i play any thing through it it sounds like the bitrate are wrong... Any suggestions??? |
Can't I just get a driver for windows 7???????????????????
I think you are in uncharted territory here. What DAW are you using with the MBox? Maybe it isn't setup for window 7 64bit. Or it can't interface with the digi drivers. That is the reason I suggested you get 8.0 because it can be updated to work with win 7. I don't think there is an update to win 7 for LE 7.
You are at a place I was at when I updated from Windows 95 to XP. DRIVER HELL!!!! I have an Alesis KB with a serial interface that I use with Finale and there were no XP drivers for it from Alesis. I ended up using YAMAHA drivers for one of their KB's. I found them about 2 days later. Good luck and let us know if you can find something that works. |
Okey. My main daw is FL Studio and I used to record in Pro Tools LE 7 when I had Windwos Xp. But now i can't use any of them with my Mbox. And I have tried Reaper that support 64 bit OS and it did't work any better there.
And I'm not sure if it will work with version 8 of Pro Tools either after reading in the forum... So i aint uppgradeing to that yet... |
Poor sound from My Mbox 2 Mini and Windows 7, 64 bit
what do i do?my mbox 2 mini worked once with the windows 7 64 bit OS and then there was a hardware error that forced the pc to shut down.I restarted it and the mbox wouldn't work properly anymore,i got a terrible hissing sound that is very frustrating.Please ill need to know if the OS is the cause of the problem and ill be glad to get useful help from anyone..thanks
Was this problem ever resolved? I can't get Pro Tools LE 7 to install on Win7. Has anyone been able to get their MBox 2 Pro to work with Win7?
My MBox 2 Pro Just sits there unused. I just tried the v8 upgrade and it says it can't detect Pro Tools LE7. Seems like I am stuck: If I can't install my licensed Pro Tools LE7 on Win7, then I can't install the v8 upgrade; therefore, I've got an obsolete piece of hardware.
Not sure this is the right place: http://secure.digidesign.com/service...&localeCode=en Didn't work Trying this for Windows OS http://avid.force.com/pkb/articles/e...ategory=Audio; Last edited by LoveFest; 06-16-2013 at 11:02 PM. |
This has already been answered in your own Thread, but I'll answer again here.
V7 WILL NOT WORK WITH WINDOWS 7. You MUST upgrade to v8 or above and only v8.04 or v8.0.5 of v8 will work with Windows 7. v9 and v10 also work with Windows 7 as will the soon to be released v11. All of these are PAID upgrades from v7. About the only place you are going to find v8 is on ebay. Cheers,
Windows 7 can not find Mbox 2 mini device drivers | fendermarshall | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-03-2012 05:24 AM |
Mbox Mini (3gen.) won't innstall drivers (code 28) windows xp sp3 | flemmingvh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-14-2011 02:44 AM |
Mbox 002 mini drivers + PT9.....HELP! | Bobalicious | Windows | 3 | 03-03-2011 11:24 AM |
Mbox 2 mini drivers for Windows 7? | ajd315 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-09-2010 03:37 PM |
Windows 7 + Mbox Mini + Standalone Drivers = ?? | FirstStep | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 11-24-2009 09:33 PM |
