Spotlight and its impact to CPU Usage when recording on a Mac.
I have read the optimization suggestions for Mac OS, (latest for 10.13);
Why does AVID suggest only disabling Spotlight when recording over 50 minutes? Question for the individuals who have a deep underlying understanding of the Mac System / OS 1 . How many of you disable Spotlight when using ProTools? If so, how do you disable? via Terminal? (I understand it is required for indexing within workspace). 2. If you don't disable spotlight are there specific "Spotlight Categories" within System Preferences that you choose to disable? 3. Maybe a different way to ask the question is do you have a method(s) you use to optimize the OS such that the Spotlight process does not or minimally impacts the CPU usage when recording however maintains workspace functionality? Last edited by jjnssn; 10-13-2018 at 09:00 AM. |
Re: Spotlight and its impact to CPU Usage when recording on a Mac.
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
Spotlight is so essential, especially if you have any samples on the same drive.. But even with audio projects, spotlight is ultra reliable to re link any missing files.. If they are on the drive, it's instant. Logic makes use of it, kontakt makes extensive use of it, spotlight is a wonderful thing.
All I do is use tinker tool system to build a fresh spotlight index on each drive once a month, the entire process takes 15 minutes a month, and my spotlight databases are always optimal size and perfectly up top date. I have *never* had a performance issue with spotlight, and I swear, for me at least, turning it off uncovers more problems than it fixes. YMMV of course, and it could very well be in my case, because I only ever record song length audio...But whatever the reason is, it's only benefitted me over here.
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
So you leave all types checked including searches and no drives in privacy? Essentially the default settings? Thank you. Sent from my iPhone using Tapatalk Pro |
is it just me or didn't they USED to have a little blurb about disabling the cmd + space bar combo in spotlight for starting a record take in PT? I'm pretty sure that was mentioned in older versions like PT8 but I went from that version to 2018.3 so I don't know when they would have stopped suggesting that. I always disable that key combo so PT can use it. I'm just surprised they don't still have that in the optimization section anymore.
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM 970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions) HD5770 GPU OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+ Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76 |
No, I turn off as much as the internet based searching as I can.
They also used to recommend turning off spotlight (these are two separate issues - key combo vs file indexing) but at PT11 (it may have been PT10), they changed to using the system file indexing (Spotlight) to match up audio clips vs running their own completely separate databases. Which is a good thing. So now you need to keep Spotlight on. However, you don't need to keep the key combo shortcut "on" for Spotlight.
Wishful thinking: a way in OS X to turn off Spotlight Search only and specifically in Pro Tools so you can use command+space record command but then when in Finder or others apps still be able to have Spotlight Search command available. Its the primary way I open apps now and love Spotlight Search command but just wish I could turn it off ONLY in Pro Tools.
MBP M1 Max | 64 GB | 4TB | macOS Monterey Version 12.7.4 [Legacy] Mobile: MBP Retina 2.6 HGz Intel Core i7 w 16 GB 1600 MHz DDR3 running macOS Catalina (10.15.7) w/ Pro Tools Ultimate 2020.12 [Legacy System] Studio: Mac Pro 2 x 2.93 GHz Quad-Core Intel Xeon w 16 GB 1066 MHz DDR3 RAM running OS X 10.8.5 using Pro Tools v10.3.9 & v11.3.2 HDX w/ AVID HD I/O |
F12 or Numeric Pad 3 both will start record. Stop record is still spacebar.
Real CPU Usage vs. Pro Tools System Usage Window | tbonesteak4dinner | Pro Tools 11 | 19 | 02-21-2019 08:04 PM |
Recording Problems-Crackling on record, Comp Shutdown, CPU usage max. NEED HELP! | Kieran-Joseph | Pro Tools 10 | 13 | 08-01-2013 03:42 AM |
Spotlight yet? | PostHuman | Pro Tools TDM Systems (Mac) | 3 | 01-12-2010 02:52 PM |
What would normal disk usage considered to be in the usage window? | Digitopian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-08-2009 09:50 PM |
MBox, CPU Usage and Recording | yogel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-23-2002 12:16 AM |
