Old 02-01-2011, 08:17 AM
Gwydion Gwydion is offline
Default DAE 1115 Error with PT 7.4 (win xp)
Hi.
I'm having some problems with my USB mbox2/Pro tools Le 7.4. I've been trying to figure it out with internet resources, but nothing seems to work.
When I launch PT after a reboot it gives me a DAE error-1115 and shuts down. With second time (most of the time) it launches ok, but there's a constant digital noise (some kind of click) on the background, witch messes up my recordings and often the program also crashes.
It seems that the error may be caused by many things, but i've tried all the fixes i found online and nothing has worked. I have tried updateing the program and iLock drivers, but i get the same error everytime. I have also tried different Usb-cables and ports and I have reinstalled software and drivers several times. In fact only one USB-port works at all with my mBox (with others the PT doesn't recognize the hardware and lights in mBox are not really bright).
I have a pretty new computer so is there maybe a compactibility issue? I have also tried running PT in Windows 7 (now i have Xp) but the whole system crashed (most of the time) when i plugged mbox 2 in. Sometimes (rarely thou) in Win7 the PT worked fine for some time but it was very unstable.
I'm currently runngin xp and win7 at same time on different partitions of the same 1Tb hard drive (I installed xp just to get mBox work) using a dualboot system. Could that be an issue? At the moment I have PT and drivers installed only in Xp
Thank you for your answers.
PS.
I posted the same information on orjo's thread on the topic (he was having similar problems.) Sorry for double posting.
My System:
Motherboard: P7P55 LX, LGA1156, P55, DDR3, CrossFireX, ATX
Processor: Intel i5 760
OS: Windows Xp professional SP3
Hard drive: 1TB Barracuda 7200.12, 3.5", SATA II, 32MB, 7200RP
Memory: 2 GB, DDR3 1333MHz, CL9
Gr. card: Nvidia GTX 460
Power: 600W "Super Series" ATX-Power.
Prgram/hardware: Pro Tools Le 7.4 with Mbox 2.
Sandra Lite information:
< Computer >
Model: System manufacturer System Product Name
Workgroup: WORKGROUP
Host Name: computer
User: Dan
< Processor >
Model: Intel(R) Core(TM) i5 CPU 760 @
2.80GHz
Speed: 3GHz
Cores per Processor: 4 Unit(s)
Threads per Core: 1 Unit(s)
Type: Quad-Core
Integrated Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64
byte line size, 2 threads sharing
L2 On-board Cache: 2x 256kB, ECC, Synchronous, ATC, 8-way, 64
L3 On-board Cache: 8MB, ECC, Synchronous, ATC, 16-way, Exclusive,
64 byte line size, 4 threads sharing
< Computer >
Mainboard: Asus P7P55 LX
BIOS: AMI 0905 05/24/2010
Bus(es): ISA X-Bus PCI PCIe IMB USB i2c/SMBus
Multi-Processor (MP) Support: No
Multi-Processor Advanced PIC (:Yes
Total Memory: 2GB DIMM DDR3
< Chipset >
Model: ASUS Core (Clarksfield/Lynnfield) DMI
Front Side Bus Speed: 2x 2.41GHz (4.82GHz)
< Chipset >
Model: Intel Core Desktop (Lynnfield) UnCore
Channels: 1
Memory Bus Speed: 2x 670MHz (1.34GHz)
< Memory Module(s) >
Memory Module: A-Data 2GB DIMM DDR3 PC3-10700U DDR3-1334 (9-
9-9-25 4-34-10-5)
< Video System >
Video Adapter: NVIDIA GeForce GTX 460 (336 SP 1.4GHz, 1GB,
PCIe 2.00 x16)
< Graphics Processor >
OpenCL Processor: NVIDIA GeForce GTX 460 (336SP 7C 1.4GHz, 1GB)
CUDA Processor: NVIDIA GeForce GTX 460 (336SP 7C 1.4GHz, 1GB)
< Storage Devices >
Seagate ST31000528AS (1TB, SAT:932GB (C:) (D:) (E:) (F:)
HL-DT-ST DVDRAM GH22NS40 (SATA:N/A (G:)
< Logical Storage Devices >
System Rev (C:): 100MB (NTFS) @ Seagate ST31000528AS (1TB,
SATA300, 3.5", 7200rpm)
Hard Disk (D:): 541GB (NTFS) @ Seagate ST31000528AS (1TB,
Hard Disk (E:): N/A @ Seagate ST31000528AS (1TB, SATA300,
3.5", 7200rpm)
Hard Disk (F:): 195GB (NTFS) @ Seagate ST31000528AS (1TB,
Optical Drive (G:): N/A @ HL-DT-ST DVDRAM GH22NS40 (SATA150, DVD+-
RW, CD-RW, 2MB Cache)
< Peripherals >
LPC Hub Controller 1: ASUS P55 LPC Interface Controller
LPC Legacy Controller 1: T0 B3-53
Audio Device: ASUS P55/PM55/3400 High Definition Audio
Audio Codec: VIA 0397h
Audio Device: nVidia GF104 High Definition Audio Controller
Audio Codec: nVidia 0012h
Serial Port(s): 1
Disk Controller: ASUS P55/PM55/3400 4 port SATA IDE Controller
Disk Controller: ASUS P55/PM55/3400 2 port SATA IDE Controller
Disk Controller: ASUS PATA IDE Host Controller
USB Controller 1: ASUS P55/PM55/3400 USB2 Enhanced Host
Controller
USB Controller 2: ASUS P55/PM55/3400 USB2 Enhanced Host
Controller
SMBus/i2c Controller 1: Intel 801xx/63xx SMBus
< Network Services >
Network Adapter: Realtek PCIe GBE Family Controller - Packet
Scheduler Miniport (Ethernet, 100Mbps)
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System >
Windows System: Microsoft Windows XP Professional
(Service Pack 3)
Platform Compliance: x86
Old 02-02-2011, 08:42 AM
Default Re: DAE 1115 Error with PT 7.4 (win xp)
Problem solved.
I followed Ojos example and bought a PCI USB 2.0 Adapter and reinstalled Pro Tools. The problem had probably something to do with my motherboard ASUS P7P55 LX.
Old 02-02-2011, 08:50 AM
Meant to say Orjo's example..
Old 02-02-2011, 11:25 AM
The Sandra report makes it look like you have a single hard drive that is split into several partitions. If that's the case, you MUST be recording to a separate physical hard drive, and not a partition of the system drive. With a desktop computer, just install a second hard drive for recording. Get a 7200 rpm drive with 32mb cache(like the WD Caviar BLACK) and format it to NTFS BASIC. Avoid any drive that uses the word "green" in its title or description.
Error 1115...HELP! jacobmoon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 04-24-2012 08:24 AM
Help! DAE 1115 Error orjo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 09-23-2011 10:40 PM
DAE Error 1115 Dtoxic911 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-11-2006 05:57 PM
error 1115 Fotrac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-11-2006 09:19 PM
DAE error -1115 saw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-18-2004 07:23 PM
