Old 02-17-2003, 09:50 AM
brahms brahms is offline
Default timecode breakup not stopping online record.
I was a bit shocked to find that when recording some material from a timecode DAT into a PT session, the online recording did not dump out when the timecode stopped momentarily and went to another point in time. It had just continued recording like there was no problem. I'm using machine control, timecode through the serial cable, and I have not selected "freewheel" for any number of frames. Any hints?
Old 02-17-2003, 05:56 PM
Default Re: timecode breakup not stopping online record.
Most devices simply phase lock... most digital devices trigger and release.. so if the numbers change, they may not be aware. Some systems have a setting to detect a change in the SMPTE numbers.. but the default is to just phase lock to the synch words in the SMPTE stream - or trigger and release.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 02-17-2003, 10:20 PM
trakbytes trakbytes is offline
I'll bet if you ran LTC into your system it would stop at timecode breaks. Personally, I have enough of a problem keeping Protools locked to continuous LTC code for long laybacks!
rcm
Save early and often! (or once a day whether you need to or not...)
Old 02-18-2003, 09:30 AM
cmaynes's Avatar
cmaynes cmaynes is offline
I think this is a known problem on the HD systems. (I have seen it happen a number of times)
charles maynes
charles maynes
sound design and recording for film and media
818 618 0580
Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC.
HTML code is On
Record stopping sounding trick EARMAN Tips & Tricks 6 09-25-2008 10:16 PM
-9136 on stopping playback/record davegibbon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-19-2007 07:21 PM
delay when pressing record or stopping record mrufino1 Pro Tools M-Powered (Win) 6 03-06-2006 09:29 PM
record stopping dat Tips & Tricks 5 12-18-2005 05:21 PM
online, locked to vid ref timecode issues garvan Pro Tools TDM Systems (Mac) 4 08-11-2003 03:39 PM
