Old 02-29-2024, 07:40 AM
Terry7 Terry7 is offline
Default C24 bypass channel eq or dynamics
Greetings: I realize there is a global bypass for eq and dynamics.
Has anyone found a way to bypass an individual channel eq/dyn plugin on the C24 without using the mouse?
-In Protools I can hold down Apple/Cmd and click on the plugin within the channel insert to bypass/engage
-On the C24 I can also hold down the Apple/Cmd modifier switch and click with mouse on channel insert and it will bypass/engage
There must be a way to do this without the mouse right?
Thanks for your help in advance.
Terry
Old 02-29-2024, 08:24 AM
tope d's Avatar
tope d tope d is offline
Default Re: C24 bypass channel eq or dynamics
Terry
Hi Terry!
Are you referring to the ones in page 41 and 79 of this page? https://cdn-www.avid.com/-/media/avi...uide_41362.pdf
-Tope
To create a support case with Avid Support, go to https://www.avid.com/learn-and-suppo...-music-support
www.topedomingo.com
Old 03-01-2024, 05:07 AM
Yes, thank you: Page 79 pushing the "Insert" button presents a bypass.
Thanks again, I missed that part...
Terry
Bypass Channel Plugins sincap Tips & Tricks 7 03-07-2018 05:42 PM
Can't see Channel Strip plugin controls (Track, Preset, Auto Map, Bypass, etc). DJ Hellfire macOS 9 05-09-2015 08:38 AM
Plug-in dynamics on channel strip gbranch VENUE Live Sound Systems 1 04-30-2009 01:51 PM
bypass all channel inserts at once tamasdragon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-31-2008 09:56 AM
keyboard shortcut to bypass all plugins on a single channel? bullyboy Tips & Tricks 2 11-01-2007 11:30 PM
