  #21
Old 06-09-2020, 11:11 AM
Third Eye Studios Third Eye Studios is offline
Default Re: 911! Anyone know the power supply for D Command?
Originally Posted by alejandro7419 View Post
Hi Rob, I am about to order the same SNP-Z10B Led PSU you bought.
I did noticed that the output of the original PSU of the D-Command has 6 pins and the one you bought has 10 pins.
do you remember which pins did you have to skip when you installed them?
see picture below :
Thanks a lot
Bumping this thread to see if you got your answer?? In case I need to replace mine in the future. Thanks!
  #22
Old 06-11-2020, 04:00 AM
crizdee's Avatar
crizdee crizdee is offline
SNP-Z107 Faders
SNP-Z10B Led
SNP-9544 Logic
Chris
Producer, Engineer,
www.ukmastering.com
  #23
Old 06-12-2020, 12:03 PM
Originally Posted by crizdee View Post
SNP-Z107 Faders
SNP-Z10B Led
SNP-9544 Logic
Chris
Thanks for that! Do you know, are the logic and LED PSU's controlling the Xmon functions??
  #24
Old 06-13-2020, 08:54 AM
crizdee's Avatar
Well i would take an educated guess the logic power supply would control all the functions. The LEDS and Faders have their own power supplies.
Do you have a specific problem tryimg to resolve?
Chris
Producer, Engineer,
www.ukmastering.com
  #25
Old 06-13-2020, 10:53 AM
Chris
Thanks for your help!! No specific problem here. Just trying to make sure I know what to do in the event of a failure. I can live without the faders if needed, but the Xmon control would be hard to deal with and patch around.
  #26
Old 07-15-2020, 04:28 AM
avantipr avantipr is offline
Contact us at Avanti Power Repairs Ltd we will be able to help with all power supply problems.
  #27
Old 12-07-2023, 03:09 PM
Skwaidu Skwaidu is offline
Resurrecting this - I have a 24f D-Command ES that is having intermittent disconnecting issues. It might work fine for weeks and then drop several times a day. Full power cycles needed to get it back up, otherwise PT will hang. The units seemingly stay powered on, But I got a hint that this might be PSU related. I happen to have my earlier non-ES board laying around, would there be any sense in trying to use the PSU's from that one as spares, even though it's over 15 years old? It was retired a few years ago with everything working except fighting faders (replaced several times).
Windows 11 23H2, Intel i9-14900KS, MSI PRO Z690-A D4, 64 GB DDR4 4000MHz/CL18, Corsair HX1000, 1TB M.2 PCIe 4.0, 5TB M.2 PCIe 3.0, 2TB QVO, 2x6TB WD Black, Noctua NH-D15, Fractal Design Define R6 + RTX4070 - PT Ultimate 2024.3
Used to be/ Spare/ DAPS: Mac Pro 4,1 upgraded to 5,1 3,46Ghz 12 Core, 96GB RAM, OS SSD and Sata3 Audio SSD, macOS Mojave, PT Ultimate 2021.10, DAPS 3.7.1
HDX2, MTRX Studio & DAD MOM, HD I/O 16x16, Apogee AD/DA 16X/X-HD and ICON D-Command ES.
  #28
Old 12-07-2023, 03:22 PM
JFreak's Avatar
JFreak JFreak is online now
New power supply costs almost a thousand euros in Finland, so just find an electrician who can fix it. Cost of parts, one euro. Cost of labour, max 100/hr.
Janne
  #29
Old 12-08-2023, 01:25 AM
Well, I'm bound to go for a bunch of S1's or something along those lines eventually anyway, just wondering about a short term fix and if it would be worth it to try to swap PSUs from the spare non-ES I have lying around (I assume it would be the logic board one that could be the main culprit).
Problem is that I'm not certain that it's the PSU, that was just something that was suggested before, that a PSU starting to fail could introduce these kind of connection glitches / leaving the board in a bugged state. It still shows "D-Command" on the strips after the dropping out.
  #30
Old 12-08-2023, 04:50 AM
I would say if you have the time, try the psu swap, couldn't hurt. When you open up the ES, you might be able to see if there are bulging capacitors in the psu.
Command 8 Power supply davpond Buy & Sell 2 12-06-2019 08:06 AM
Where can i buy a Power Supply for my D-Command ? francois ICON & C|24 21 02-28-2019 05:28 PM
Command 8 Power Supply question MarkH ProControl, Control|24, Command|8 6 09-20-2017 05:11 PM
Command|8 Power Supply? stuseattle ProControl, Control|24, Command|8 5 05-03-2012 04:33 AM
Command 8 Power Supply infernojs ProControl, Control|24, Command|8 3 10-03-2005 12:59 AM
