#41
Re: Protools 11 Recording Timing
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#42
yep...sounds like issues that we reported in PT9...with the 002 at that
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#43
OK so I think we're in the same boat, although your sync is bit worse than mine. I took another look at my session and actually I also have a small discrepancy between the original click and the new one with delay compensation off - which is 4 samples. Something is clearly amiss with the delay compensation in PT11. Out of interest what sample rate were you running at? |
#44
For what it's worth, I performed the test mentioned by miketeachesclass in post #31 exactly as described.
I'm on Windows 8 and I am working at 96kHz. PT 10.3.6 HD Native With Delay Compensation off: recording is 45 samples late at 96kHz With Delay Compensation on: recording is 22 samples late at 96kHz PT 11.0.1 HD Native With Delay Compensation off: recording is 45 samples late at 96kHz With Delay Compensation on: recording is 22 samples late at 96kHz I get no difference between 10 and 11, but in no situation is the recording perfectly aligned as others have described. Does it look like I'm doing something wrong? mykhal I know you have a similar system to mine ... are your results similar?
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1 |
#45
#46
#47
kool...do you still have your RME gear? or any gear with ASIO drivers?
#48
Open up setup > I/O > input > check "compensate for input delays after record pass: on my tests 44.1 is 1 sample late 96k is perfect. buffer size or latency compensation does not change the results. What did you mean by shutting the adc off in 11?? you cant just turn it on and off like previous versions of PT
#49
Only thing I have left besides the HDN is the Eleven rack.
#50
Select a minute or so of time in the edit window Bounce to disk Select offline and save it Drag in in the edit window onto the timeline.
Recording timing / late recording issue resolved | DAWgEAR | Pro Tools HDX & HD Native Systems (Win) | 0 | 07-17-2013 09:10 AM |
MP 9 Recording; Timing Issue.. | alchemical.dream | Pro Tools M-Powered (Win) | 1 | 05-01-2012 11:47 PM |
Recording Timing Problem | Jenre | Pro Tools M-Powered (Win) | 1 | 07-02-2010 02:44 AM |
Recording MIDI - Timing Off | haashole | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-24-2007 06:52 AM |
Recording Midi:Timing problems | Gothboy | Digidesign Hardware & Software | 0 | 06-16-2006 07:36 AM |
