Old 06-23-2013, 09:29 AM
ADFJamesAudio ADFJamesAudio is offline
Default iLOK activation was working then stopped
I managed to activate everything for last night and was using PT11 for a good hour after which I shut it down then turned off my computer (macbook). When I tried to open protools11 again this morning my iLOK no longer worked to authorise it and I don't understand as literally the only thing that changed was my location, being at the studio rather than at home.
All morning the iLOK manager has been saying my iLOK has 2 activations (protools 10 and 11) and suddenly an hour ago it switched to saying 0 activations and it now won't activate again.
Any help would be much appreciated.
Old 06-23-2013, 09:31 AM
Park Seward's Avatar
Park Seward Park Seward is offline
Default Re: iLOK activation was working then stopped
Sounds like more iLok problems.
If you you have not yet placed a support request, please submit a Support Ticket at iLok.com:
https://www.ilok.com/support.html?type=gn
Park
The Transfer Lab at Video Park
Analog tape to Pro Tools transfers, 1/4"-2"
http://www.videopark.com
MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays,
Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax.
Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track.
Old 06-23-2013, 01:15 PM
Paawo Paawo is offline
I had the same problem on Win7.
First everything was working fine, both PT10 and PT11, was testing opening old projects and creating a test project with PT11 etc.
Then suddenly trying to start either PT10 or PT11 would give an authorization error. I also noticed that the new iLok manager gave some error message when trying to log on, and the iLok did not turn up on the list.
I uninstalled everything iLok I could find and then reinstalled the new iLok License Manager only. Now it works again.
There are now less PACE instances in the win7 "uninstall a program" list, so I guess it may have been some old PACE driver or SW causing the problem.
Well, lets see how long it lasts.
(As a side note... after doing the uninstallation of suddenly the PT10 stopped reading any old projects, giving a "could not complete the Open session... command because of converting tracks" error. I did a repair installation of PT10 which did not help, but doing a repair on PT11 solved the issue for now... )
Old 06-23-2013, 07:26 PM
mhuang mhuang is offline
thought it was safe to upgrade PT, now I am in ilok hell...
this morning: installed pt10.3.6 and pt11, ILM detected the license on my ilok and i was able to use pt11 for a hour before I shut down my macbookpro. now when I start up pt10 or 11 I get an unauthroized error, when I start up ILM, it now no longer recognize my ilok as plugged in.
Old 06-23-2013, 07:57 PM
ok, found a temp solution, seems like everytime I reboot my macbook, ILM no longer recognizes my ilok, the solution I found is to uninstall ILM and reinstall it again everytime i boot up my macbook. *sighs*
iLok has stopped working, OS 10.4.11 GRock41 macOS 10 08-07-2013 12:45 PM
iLok just completely stopped working. Such BS jakedavis Pro Tools 10 4 01-31-2013 07:04 PM
ilok authorization stopped working. help please mixskywalker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-21-2012 09:07 PM
Why Has Ilok Suddenly Stopped Working kimballob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 07-24-2008 06:03 PM
Ilok just stopped working! beech Pro Tools TDM Systems (Mac) 9 10-06-2003 08:56 PM
