Old 12-16-2018, 08:47 PM
eden909 eden909 is offline
Default Can't activate Avid Falcon AAX license
Almost a week after it was promised AT THE LATEST, the license arrived in my account. iLok doesn't like it. It says it's activated in the cloud but cannot be moved to my iLok even when when I follow iLok's instructions.
Old 12-19-2018, 07:54 PM
jeffro's Avatar
jeffro jeffro is offline
Default Re: Can't activate Avid Falcon AAX license
You can't move a license from iLok Cloud directly to an iLok - first Close Cloud Session in iLok License Manager then activate the license to your iLok.
linkedin
Old 01-28-2019, 11:32 PM
DumbIT DumbIT is offline
Me too.
1. Downloaded/installed UVI Falcon from AVID ProTools Site
2. ProTools 2018.7 is under valid/current Annual Plan (and runs OK)
3. Falcon is available in PT as plugin, but demands authorisation despite ...
4. iLok Manager (v.4.1 AND 5.0.1) saying the UVI license is iCloud Activated, BUT
5. Can't drag to iLok OR deactivate on the Cloud, and the "Transfer" button is greyed out. Dragging gives: "...can be moved back to your account only when you close your cloud session using the File menu" ... but doing this means I can't SEE the license to access it!
Old 01-28-2019, 11:39 PM
** SOLVED **
The official solution pre-supposes that you use a "Cloud Session". (I never do ... I'm a simple user with everything is on my iLok.)
So the CORRECT SEQUENCE that fixed the problem for me is:
• OPEN a Cloud Session (from the File Menu)
• Double-click the Avid Falcon AAX license and click "DEACTIVATE" to the right of the details pane (note the message, but follow the next steps)
• FILE> Close Cloud Session
• Check that the License now has a spare activation available (mine said “0 of 1 Activations used”)
• Drag the Licence to your iLok
Old 01-29-2019, 10:30 PM
jeffro's Avatar
Originally Posted by DumbIT View Post
** SOLVED **...
Glad to hear this!
...Double-click the Avid Falcon AAX license and click "DEACTIVATE" to the right of the details pane...
Right+Clicking a license provides the same Activate/Deactivate options, but you can't Deactivate licenses individually from iLok Cloud. Could it possibly have been activated to your Computer?
linkedin
Presets for Avid Falcon AAX? b mcgibney Virtual Instruments 6 04-24-2019 05:39 AM
Avid Falcon AAX license/installers not provided senghor Licensing & Accounts 41 01-09-2019 09:57 AM
Load avid/presets to uvi/falcon every time kmusic AAX Plug-ins 0 12-06-2018 03:49 PM
PT 7.4HD License - Can't Activate Siegfried Meier macOS 12 11-22-2015 11:21 AM
License Activate JPaton Pro Tools 11 0 06-26-2013 07:09 PM
