#111
Re: Todays Key Command Is.........
is there a key command to toggle the latch solo?
!#$@@$#! "Do not fear mistakes. There are none." Miles Davis |
#112
"is there a key command to toggle the latch solo? "
Not that I know of. Because of this, I wrote Quick Keys to do just that and record latch as well. It's the only solution that I know of at this point. |
#113
would you care to share the QK?
#114
I got a new Pro Tools 6 only shortcut.
Found out you can resize the Movie Window. To make it smaller, Control - Option - Command - Click it. To make it bigger, just Control - Option - Click it. Tested it in Pro Tools v5.1.1, but it didn't work. Maybe this shortcut is documented somewhere in the manuals, but I haven't seen it. I know the people at Digi are working hard, but I wish they would tell us all the features they're implementing. Can only make me think better thoughts about them and Pro Tools. |
#115
Todays Key Command Is.........Questions
Has anyone found a way to copy sends from one track to another in the same way one can copy an insert plugin by option-dragging? That would be nice.
Also - any keycommand to toggle TAB TO TRANSIENTS? Or Unmount Drive in the new digibase workspace browser? I've got Quickeys and am using it extensively as well. |
#116
<<not a key command but a question to ..... session is in scroll during playback. If in play and you don't select anything, session scrolls further page by page. if I make aselection during playback and edit during playback the page stays at the edit position. How to hit a key to let the session scroll again ? >> ================================================== === In PT 6 there is a little indicator at the top in the time line on either the left or right (depending on which way you need to go to get current) clik on the indicator and you will be brought up to the current location.
Thomas Anthony Natural Sound |
#117
Command+Shift+Delete
#118
#119
As for another keyboard shortcut, Option+Apple+/ allows you to write plugin settings to a region. This is great if you have several different sources for sound on one track and want to automate your plugin for each region.
#120
thanks
Life is good !! Marcello Azevedo |
What cabling and connections into todays studios? | digidesigner | Pro Tools TDM Systems (Mac) | 2 | 08-10-2010 05:00 PM |
"...todays most doped foley-artist-tricks" | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 04-08-2004 03:23 PM |
Need Engineers Input on Todays Recording Industry | Eddie D | General Discussion | 2 | 12-01-2003 10:13 PM |
PT LE 6 upgrade just came in todays mail | mgbasinski | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 02-09-2003 05:23 PM |
Todays the 15th, Where is it??? | Kenny Gioia | General Discussion | 19 | 02-16-2001 12:51 AM |
