Old 08-10-2010, 06:12 AM
digidesigner digidesigner is offline
Default What cabling and connections into todays studios?
I'm looking into some suggestions about what types of cabling would be wise to install in between a studio and a control room in today's situation. It's a Post Production place that would like to do music recording as well. Bunch of CAT5 in addition to analog pairs? Opticals, if so then what kind?
Old 08-10-2010, 12:25 PM
SoundReplay SoundReplay is offline
Default Re: What cabling and connections into todays studios?
I'm using Vovox cabling for analog and AES/EBU.
Check out http://www.vovox.com
Greetings,
Dirk
www.soundreplay.com
Old 08-10-2010, 05:00 PM
jeremyroberts jeremyroberts is offline
Greetings,
Dirk
They claim that their cables have DIRECTIONALITY
Running direction
VOVOX® sound conductors offer their full potential when they are used in the correct direction. Regardless of the application, the best results will be achieved by plugging the cable end with the VOVOX® label into the signal receiver. In the case of XLR cables, the correct direction is unavoidable, as there is only one way to connect the cable and receiver.
In case of wrong alignment, VOVOX® sound conductors will work properly, and there will be no damage to the connected equipment. But to optimize the cable’s use, follow the directions above.
http://www.vovox.com/neu/content_e/00_01_03.html
Uh, yeah. Right.
--Jeremy
Todays Key Command Is......... GKB Pro Tools TDM Systems (Mac) 133 08-20-2016 11:13 AM
SPDIF cabling vs. Hi-Qual RCA cabling - difference? SixChurchStreet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 04-12-2007 04:16 PM
Need Engineers Input on Todays Recording Industry Eddie D General Discussion 2 12-01-2003 10:13 PM
PT LE 6 upgrade just came in todays mail mgbasinski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 02-09-2003 05:23 PM
Todays the 15th, Where is it??? Kenny Gioia General Discussion 19 02-16-2001 12:51 AM
