Old 11-22-2015, 03:58 PM
brentalight brentalight is offline
Default Question - PT12 or Eleven Rack
Trying to find some info about the Eleven Rack. I'm planning to buy a subscription for ProTools 12 and was thinking maybe I should jump on the Eleven Rack also. I currently have a Focusrite Scarlet 18i20. Should I even bother with the Eleven Rack? I know ProTools 12 comes with the Eleven Rack plug ins. Seems the benefit with the Eleven Rack would be outboard processing. Is there any way I can use both my Focusrite and the Eleven Rack and what would the benefit be? Dont want to spend the extra money if I dont need to. I can get student pricing on the software alone.
Old 11-22-2015, 05:20 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Question
With the release of the Eleven MKII plugin and the 11 effects, there isn't a huge benefit in owning the rack for just recording. One advantage of the rack is that the effects are stored with the presets. Another nice thing is that you don't have to fire up the computer and PT if you just want to practice or try out an idea.
Your Focusrite interface has SPDIF connections, so you could continue to use that as your PT interface and connect the 11R to it via the SPDIF connections.
I personally like having both the plugin and the rack. I use the plug in for recording and use the rack practice and occasional live use.
Will
System Details
Old 11-24-2015, 04:55 PM
DonaldR DonaldR is offline
Eleven rack replaced my guitar amp, my multi-effect and my bass amp. So yes it's worth it for me. Just for recording? Yes I think it might worth it also as already said you can practice, jam, and try out ideas without booting the computer.
Old 11-24-2015, 09:57 PM
The Focusrite driver will show up as either Core Audio or ASIO depending on your Operating System in Pro Tools. My personal view on the Eleven Rack over plug-in versions is primarily focused on the physicality of the device, that is a perpetual accelerator. RTAS maybe replaced, AAX maybe replaced but a dedicated hardware device that can output audio, doesn't require you to stay current and thus always yours. That's got to be superior, no?
Aaron Mulqueen - 001 HD Native
Old 11-25-2015, 09:16 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Question - PT12 or Eleven Rack
.....use the rack practice and occasional live use.
Yes to all of the above, keep using the focusrite and Spdif into it, doesn't matter if your using Mac or win and they aren't qualified - Spdif works all day long
Originally Posted by DonaldR View Post
Eleven rack replaced my guitar amp, my multi-effect and my bass amp. So yes it's worth it for me..
Agreed, live use....amazing. The same tones you recorded with in a live setting
Daniel
Old 12-09-2015, 10:26 AM
Thanks for all the replies folks! I went ahead and pulled the trigger. It should be here in a few days. I'm not that familiar with hooking things up using SPDIF connections but what you are saying makes sense. I also have a Lexicon RM400 reverb unit. It has the capability to work in Pro Tools as a hardware VST allowing you to process reverbs via external gear. They recommend using SPDIF connection to your interface with this also. Can I connect multiple devices via SPDIF to my Scarlett 18i20 or will I need to use analogue I/Os for that? The RM400 connects via USB for editing and control but does not pass audio via USB. Has to be SPDIF or the I/Os.
Old 12-09-2015, 09:56 PM
nst7 nst7 is offline
You would only be able to use one spidf unit at a time. If you had to choose, i would sooner use the Eleven Rack via Spidf and hook up the reverb via analog.
On the other hand, you could just switch back and forth, as I presume you would be using the Eleven Rack for recording, and the reverb unit when mixing.
Old 12-10-2015, 04:40 AM
Good point. Simply switching the connection to the Lexicon when needed is probably the best bet. Think I was getting wrapped up in a static signal chain. No real need for that.
Thanks!
Eleven Rack i/o question? jc7 Eleven Rack 3 12-13-2012 01:21 PM
Eleven Rack Question JoshuaCLS Eleven Rack 1 12-08-2012 04:55 AM
I/O question Motif Rack ES & Eleven Rack greenetunes MIDI 4 05-27-2012 07:47 PM
Eleven Rack/PT question Intelli-Shred Eleven Rack 3 02-22-2012 05:15 AM
Eleven Rack & 003 Rack+ question deadshot 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 04-29-2011 12:14 PM
