Old 02-12-2020, 06:39 AM
Ale Ale is offline
Default S1 Faders kick back a little when untouching
Hi dear S1 users.
As i got now no answer from support since one month on my case (Case is still in review) it would be great i you can tell mee if you see the same behavior.
When I write automation (does not matter what mode) the fader always jumps a little back to the direction where I was coming from.
Often it also writes a new level. When I retouch the fader the level writes new level into protools which differs 1-2 dB
Ale
See the video with my problem:
http://www.tonstudio-gress.de/downlo...ickingback.mp4
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 02-12-2020, 04:40 PM
mixboy bob mixboy bob is offline
Default Re: S1 Faders kick back a little when untouching
I have this also, as well as a jump when touching the fader. This definitely needs a fix, as accuracy is important on both dropping in and out of a fader move.
Needs a fix badly....
http://www.robburrell.com
PTHD Ultimate/Eucon (latest betas) / Mac Studio Ultra 128GB RAM / Aja T-Tap / Sonnet M.2 4x4 PCIe 8TB / Focusrite 16Line / MTRX Studio / UAD Octo / 32 channel S1 & Dock (5) 2019 Fire HD 10 / Dolby Atmos 9.1.4 /Mastering Suite / 13.0 Sony 360RA
Old 02-12-2020, 09:49 PM
EddieJones's Avatar
There's another post about this. It will be improved some what in tomorrow's release and then more in the 20.4 release.
Sent from my HMA-L29 using Tapatalk
Old 02-13-2020, 05:44 AM
Sweet!! Thanks again for all your work, Eddie!!
Old 02-13-2020, 12:14 PM
Lynn Gräber Lynn Gräber is offline
This is still happening after firmware update and Econ update 20.1
Old 02-13-2020, 12:52 PM
EddieJones's Avatar
Can I clarify which issue. If you move the fader with the mouse to 0db in PT and then touch the fader cap...does the value jump ?
Old 02-14-2020, 01:23 AM
Ale Ale is offline
This behavior is much better now.
But it still happens. With older software I had sometimes differences of 2 dB.Now it seems to be 0 to 0,5 dB which seems to be acceptable at first glance.
But the other problem ist still not fixed. The fader jumps back a little during a record pass when untouching the fader.
This jump back get sometimes recorded which is not good.
See the pictute attached. It 1 dB Difference. (breakpoint jump in the middle) or have a look to my video in the first post
Ale
File Type: png Bildschirmfoto 2020-02-14 um 10.16.05.png (7.3 KB, 0 views)
Old 02-17-2020, 08:28 PM
EddieJones's Avatar
We already have a fix for this in test and I'm looking at doing another dot release if it works out.
Old 02-17-2020, 11:31 PM
Ale Ale is offline
That’s very good to hear Eddie
Did you also find a solution on the most annoying bug?
The stop writing bug after 47 to 50 seconds?
Ale
Old 02-18-2020, 05:37 AM
Any chance of fixing the previously working/now broken VCA spill/view filter? This is a real workflow killer and it was so perfectly beautiful before this update. Pretty please???
Looping an 8b drum loop makes my first kick double when it loops back DBK Getting Started 2 10-12-2015 02:29 AM
Faders fighting back remainanon ProControl, Control|24, Command|8 8 06-02-2009 02:46 PM
003 faders sticking/jumping back to 0 steve mezclador 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 09-15-2008 11:27 AM
How do I change a session back to +6dB faders. SilkBasilar Pro Tools TDM Systems (Mac) 5 04-24-2006 06:11 AM
how do i back down all faders in unison? maskedman72 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-21-2004 11:18 AM
