Old 12-07-2019, 08:12 PM
dark_side dark_side is offline
Default Tube guitar preamp with eleven rack
Is there worth of buyin additional tube preamp for eleven rack to improve the sound ?
Connecting it into fx loop and bypass amp modulation.
Does anybody made some kind of comparison between "Eleven rack amp+cab into DAW" vs "Guitar Tube Preamp+Eleven rack cab into DAW"?
Im thinking of buying Triaxis for under 500$ but does it worth it ?
Thanks for attention
Old 12-08-2019, 04:10 PM
Default Re: Tube guitar preamp with eleven rack
Just my personal opinion; if the Eleven Rack doesn't give you the sound you want, then its not the right hardware for you. Adding another preamp would not be something I would do. If the TRIAXIS gives you the sound you want, use that and add a proper effects processor. You could also consider the Line 6 Helix or the Kemper Profiler as both are very good units(and both benefit from many years of improving technology over the Eleven Rack, which is nearly 10 years old)
Old 12-08-2019, 07:02 PM
Thanks for reply!
Im in love with my eleven rack. But im just curious : maybe it can sound even better with external preamp?
Old 12-08-2019, 08:00 PM
Southsidemusic's Avatar
Originally Posted by dark_side View Post
Thanks for reply!
Nope!
If you want better sound get something else like we did. Got the Kemper Profiling Amp and The Axe FX3 which both smokes the 11rack even though the 11 rack is a great piece of gear and worth a lot more than we paid (225 USD) and the kemper and Axe were 10 times that or more.
A preamp wont make the 11 sound better as it already has preamps so a few pedals with some cool effects and distortion will do a lot more for the sound than a preamp which wont change the sound enough to ve worth it unless you get a really high end piece of kit.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 12-08-2019, 10:12 PM
^^^ What Chris says. Esp. the AxeFX if you are into high-gain/metal amps.
But also the sound of your Eleven Rack might just need you playing with it more. Don't just rely on presets, really play around with stuff, including gain staging from your guitar. If you describe here what you are doing, what ER rig settings you are using, guitar and pickups etc. then folks might be able to suggest stuff. The Eleven Rack is an amazingly capable box for the money. Sad to see it fade away...
Old 12-11-2019, 01:17 PM
DonaldR DonaldR is offline
Will not really work as there's no poweramp emulation in 11R.
So adding the Triaxis preamp in front of whatever amp will cascade 2 preamps, will no sound good or at least will not sound better.
Years ago, a friend of mine tried my 11R connected to my tube preamp into 4x12" Celestion G12K100 cab and he said it sounded totally insane. He used to have a Triaxis
Problem Eleven rack with tube amp Greenwilly66 Eleven Rack 6 02-17-2017 02:36 PM
Guitar Preamp Before Eleven Rack? mattz63 Eleven Rack 7 09-24-2015 12:47 PM
Eleven Rack Mic Preamp Becharax General Discussion 54 02-26-2015 05:52 AM
Can I go Guitar>Pedals>DI XLR out to Eleven Rack? (using Mic input for guitar) electricfiddle Eleven Rack 5 12-12-2011 06:57 AM
Need advice on using Eleven Rack with tube power amp plus a 4-12 cab mick828 Eleven Rack 8 10-05-2011 05:18 PM
