Old 10-06-1999, 02:09 AM
shipmen shipmen is offline
Default USB midi & HUI
Hello all
I have just recieved a G4, and set it up with PT24MIX plus & HUI, and a Roland USB MPU64 midi interface.
Running PT and SV PRO (opcode) atb the same time, with SV pro set to MIDI only, using it as a sequncer.
Everything works fine, except when I use the CHANNEL or BANK buttons on HUI to move between channels, glitched occur in the MIDI playback of Studio vision PRO.
I have all the latest drivers & versions for everything.
I just borrowed the Roland I/face to test USB for MIDI.
Befor this setup, I had a B/W G3 with stealth port and opcode studio 64. It worked fine.
Maybe it is the Roland USB I/F. I may need something like A unitor MKII USB, or an OPCODE USB when available.
Any other users with USB midi problems ?
Old 10-06-1999, 05:34 AM
GROS GROS is offline
Default Re: USB midi & HUI
i noticed the same problem but in protools. i am however using a usb interface but not thru usb connection.(SERIAL) MIDI EXPRESS XT
it has a serial port.but this only seems to effect the midi.
dr 770 (boss dr rhythm 770) as midi controller/midi output to 11r midi input yellow Eleven Rack 1 05-04-2012 03:33 PM
003 midi ports not there in midi studio setup? Unable to record midi now? TREBLEBLEED 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-22-2009 12:06 AM
MIDI Questions On IMPORTING MIDI & Recording MIDI Pro Tools LE 7.4 Michaeldante MIDI 3 03-27-2009 05:42 PM
USB midi vs. din midi-(the old style midi connector) Ling Pro Tools M-Powered (Win) 1 02-19-2009 02:15 PM
Assigning MIDI sounds to MIDI controller and playing sounds with MIDI lalalandguy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-02-2009 12:52 PM
