How much memory for DAE and PT?
I have PT 4.3.1,d24,mix farm and 2DSP farms in my 9600/300/192mb.I also have following plug-ins:Waves Gold bundle,Pro FX bundle,MDT,Lexiverb,TC Megareverb,Hyperprism,TC Tools,Auto Tune,Amp Farm.I use my MLCD quite often and ocassionally Logic Audio 4.0.
How many mb should I assign to DAE and PT for the best Pro Tools performance with 192mb available in my computer? |
Re: How much memory for DAE and PT?
You know there´s a minimum/maximum field.
what should they be on? Mats |
smack
The minimum memory setting should be left at it's default. If you've changed this type the number 0 in the minimum field and press return. This will default the minimum memory setting. Pro Tools preferred (maximum?) memory should be set to @35-45MB and DAE preferred should be at @40-50MB. If your using Waves plug-ins increase this a little more. Brad |
Kontakt Memory Server (KMS) Could not start MemoryServer. Memory Extension will be... | John_Toolbox | Virtual Instruments | 5 | 12-29-2011 10:03 AM |
MEMORY ERROR MESSAGES- Strange memory loss | hwill2008 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-23-2010 08:14 AM |
Memory is Low? Quit and Allocate more memory to PT | Unite | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-08-2004 05:38 PM |
Will PC2700 memory work in PC2100 memory slot? | dfusion | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-08-2004 09:30 AM |
Promting lack of memory on PC with adequate memory! Any tips? | will22 | Digidesign Hardware & Software | 12 | 09-20-2001 08:36 AM |
