Old 03-30-2021, 04:36 AM
spoons's Avatar
spoons spoons is offline
Default Re: Lost the S1 modifier soft keys.
Looks the same as mine. Attached
Thinking I may have to start again with a un-install ..
Richard Spooner
Ultimate, S1, Dock, Monterey , MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 04-13-2021, 02:28 PM
wyman wyman is offline
I just updated to 2021.3.1 and my customized soft keys got wiped and reset to the defaults shown on those screenshots, too. It's been a minute since I originally programmed them, so I don't remember if this was how I did it originally, but for modifiers:
Make sure to open the EuControl settings from Pro Tools (it programs the soft keys specific to the application)
Choose "Soft Keys" from the top menu
Choose "S1 Track Color Keys" from "Section" menu
Select the Softkey on the EuControl Graphic you wish to assign a modifier to, then click the "Command" button in the EuControl window
Click "Add New" and select "Eucon" from the menu
Under "Details," scroll down until you see "OS Modifiers." Assign the desired modifier to the soft key. Lather, rinse, repeat.
Hope this helps!
Old 04-13-2021, 02:32 PM
EddieJones's Avatar
They didn't get wiped and are still there on your computer, you just need to open them. In the next release we have put a new dialog that gives you the option to import them instead of having to manualy search for the file and load it.
Old 04-13-2021, 03:41 PM
spoons's Avatar
Hope this helps!
Thanks for your post. I’d actually worked this out a few days ago. I now have the modifiers back on those keys as you described.
This brought up another problem though. For example, the shift modifier key works fine as it would on the keyboard for editing etc but it doesn’t work as a shift on the S1 or Dock ? Holding that shift and pushing another key on the S1 doesn’t give me the shift function for that key? It doesn’t make the shift key on the S1 or Dock light up either. Is this normal behaviour?
Richard Spooner
www.spoonsound.com
Old 04-13-2021, 03:50 PM
I wonder if your original settings may be stored somewhere on your computer as Eddie suggested when replying to my original post, and if that might help? Perhaps he could suggest where to look?
  #16
Old 04-13-2021, 06:31 PM
EddieJones's Avatar
here: https://avid.secure.force.com/pkb/ar...391?popup=true
S1 Modifier Keys for Logic sjgam Avid S1, S3, Dock and Control App 1 04-01-2020 07:47 AM
S1 modifier keys not set up supercharge Avid S1, S3, Dock and Control App 12 03-31-2020 01:59 PM
S6 Bug Report: Shift Modifier Latching with Soft Keys Dan Smith Avid S4/S6 3 05-29-2016 01:39 PM
Lost Automation Modes Soft Keys in 2.5.6 mystic merlin Artist Series 19 05-23-2011 02:21 PM
C|24 Modifier Keys in 8.0.3 paulmellors ICON & C|24 1 02-10-2010 08:46 AM
