Random "pre-midi notes" before real note
I notice when I record a bass part from my controller using the Trilian bass module that there are these "pre-midi notes" that appear right before the real note i played. If I don't go in and physically remove them; when I quantize the notes sound all weird. Anyone have this issue? If so, how do I stop these from appearing alltogether? Thanks! |
Re: Random "pre-midi notes" before real note
Couple of questions:
a) Can you give us details on your controller, and how you have the controller hooked up (MIDI+ USB MIDI Interface or USB directly) b) Are you recording the MIDI directly on the Trillian Instrument track, and have you tried creating a separate MIDI track and assigning this to the Trillian?
Eddie Sullivan Long Island Mac Tech http://long-island-mac-tech.com [email protected] 631 786 3924 Freelance Mac/Pro Tools tech for hire. Metro New York Area. |
I have my Axiom pro hooked up to my Mbox 2 pro via USB. I open a stereo instrument track, open the Trilian on it, open a mono midi track where the midi gets sent and recorded. Does that help? |
it kind of helps- except that the Axiom Pro typically does not hook to the MBox with USB, it could either hook up to the MBox 2 via a pair of MIDI cables, or hook directly to the computer via USB.
Can you try hooking the Axiom directly to the Mac via USB and checking that you have the latest drivers for this device at m-audio.com? You also want to open AMS (the Audio Midi Setup) found in Applications->Utilities and make sure that the Mac OS is seeing the Axiom properly in the MIDI Pane...
My bad.....The Axiom is hooked to my Macbook via usb and I have my midi cables going to and from the Mbox.
I haven't tried the drivers. Maybe that's it..... |
Why do you have USB *and* MIDI cables- typically you want one or the other. This may be the cause of your ghost notes- try disconnecting the MIDI cables, check the drivers and AMS and see what happens...
I am so dumb.....I just thought the midi information had to go through the Mbox. I will unplug them and check the drivers.....
So, I just need the USB cable to the Macbook? Nothing to the Mbox? Thank you! |
The MIDI Interface built-into the MBox is really to hook up MIDI equipment that does not have USB on it (like older keyboards, or some modern sound modules that are MIDI only) - you could hook the Axiom up via MIDI and the MBox- but the better way is really USB. You definitely don't want both : )
Let us know if this solves your problem!
Midi Export -> "Apply Real Time Properties" Question | Sparky1 | macOS | 2 | 12-12-2020 04:54 AM |
"wait for MIDI note" is not working | montelee | macOS | 3 | 05-08-2015 11:33 PM |
MIDI editor: display note "names"? | mike_mccue | Pro Tools 9 | 5 | 11-12-2012 04:35 AM |
MIDI note Latency . . . live keyboard playing is a "little behind" | The Zone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 11-09-2012 05:33 PM |
Probable bug in "notes" view on midi channel with smart tool | farmfresh | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 01-30-2009 11:07 AM |
