Re: Low res audio being recorded.
It sounds TERRIBLE like it has a bit rate of 4Khz even though it is 48Khz.
3 X Z440 W10 32GB RAM, PT 2022.10/2022.4 HDX, 1 X Omni, 3 x X-Mon/S6, 1 X Scarlett Solo, 4 X Blackmagic 4K Extreme, NEXIS E4, Isis 5000, S6 X 3. Synced with Nanosync Word clock. |
How can you tell for sure unless you are exporting? in which case you have to select 48 instead of 4 in the export dialog.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
I checked the actual file it recorded to the HDD.
Then I might be right, you must be exporting at 4kHz. When you export the final audio in Pro Tools make sure to find Sample Rate and select 48kHz before export.
I'm not exporting anything. I am checking the ACTUAL file I recorded when the VO was made into the AUDIO FILES folder. It doesn't get any simpler than that.
What are you using to check the file? Another program? If so what program and what does it say about the file's bit rate? What levels did you record at? Did anything go into the red?
I'm not sure your problem has been communicated very well. Just to be clear - you are running Avid HDX hardware with Pro Tools, but all of your Windows 10 audio (playing a file from the audio file folder, soundminer and RX) is routed to your Blackmagic interface. Correct?
And you can record and playback audio just fine within Pro Tools? So Pro Tools and your HDX card is working just fine? But when you try and play back audio through Windows 10, which is set to your Blackmagic card, such as straight from the audio files folder of a Pro Tools session, or from Soundminer, or from RX, you have sound quality issues? That points to your Blackmagic card being the problem. Have you tried plugging the Blackmagic card straight into your monitors to determine if it is working ok? Have you tried selecting your Avid HDX hardware for Windows 10 audio, which bypasses the Blackmagic altogether, to see if the problems suddenly disappear? Have you tried any troubleshooting steps to narrow down the issue? If the Blackmagic interface and HDX aren't playing well together, try and figure out if they are playing well when separated. On a side note, the way you currently having the Blackmagic card feeding HDX via analogue means you are probably actually losing sound quality. You really should consider doing it digitally (AES, optical spdif, etc) instead, as well as jamming the Blackmagic to HDX's word clock.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Problem solved. Re-arranged the order of the cards and now no low-res audio recorded. When I installed 2019.5 I had permanent low-res audio in Pro Tools even before starting any apps that used the BM audio card for monitoring.
WORKING SOLUTION: SLOT 1: INTEL 9002 NIC SLOT 2: Nvidia K4200 SLOT 3: BLACKMAGIC 4K EXTREME SLOT 4: HDX
3 X Z440 W10 32GB RAM, PT 2022.10/2022.4 HDX, 1 X Omni, 3 x X-Mon/S6, 1 X Scarlett Solo, 4 X Blackmagic 4K Extreme, NEXIS E4, Isis 5000, S6 X 3. Synced with Nanosync Word clock. Last edited by ShadeTek; 05-27-2019 at 03:49 AM. |
Recorded audio sounds off. Please help | SpaceChocolate706 | Pro Tools 9 | 1 | 08-21-2015 10:06 AM |
Audio can't be recorded in PT 7.3.1 | arjohe | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-12-2009 08:54 AM |
Best way to edit recorded audio? | Che_Guitarra | General Discussion | 2 | 11-15-2007 11:07 PM |
Recorded Audio Not in Time bug Audio always early | Hawkeye | Pro Tools TDM Systems (Mac) | 6 | 10-20-2005 11:57 AM |
No audio being recorded in PT | DrBackshots | Pro Tools M-Powered (Mac) | 0 | 10-05-2005 10:28 AM |
