Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 02-23-2021, 06:21 AM
colluluigi colluluigi is offline
Default wave deformee
bonjour
a tout hasard je post mon probleme ici sait on jamais
voila je me suis apercu que la piste guitare avais l image de la wav rabotee sur le dessus quelcun a deja eu ce probleme ?
CI JOINT LA PHOTO
merci d avance
Old 02-23-2021, 07:05 AM
Default strange wave
Hello anyway I post my problem here we never know here I noticed that the guitar track had the image of the planed wav on top, someone has already had this problem?
here JOINT the Picture thank you in advance
protools 2020.5
win 10 64 bit
Old 02-23-2021, 08:09 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
Default Re: strange wave
Is this a DI or amp?
Active guitar? If so check the battery, it could well be going flat.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 02-23-2021, 09:55 AM
paul_g's Avatar
paul_g paul_g is online now
Do you have compression or limiter on?
Track looks pretty slammed... What levels were you recording at, I typically never record beyond -12 db, peak maybe at -6db. If using USB via HX Stomp, I have no control over in-put level, but it's usually -16 to -12.
Have you increased the size of the wave form display? You might want to check that too.
5K Retina 27" (2020) iMac OS 13.6.5 Ventura
3.3 GHz 6-Core intel Core i5
AMD Radeon Pro 5300 4 GB
64 GB 2667 MHz DDR 4
Internal 2TiB SSD
Pro Tools 2024.3
EuCon 4.8.6.41 / 2023.11
UA Luna
UAD 11
UA Apollo Twin X
Avid S1 / Fire10 - 21.8.1.0
PreSonus DigiMax FS 8-input ADAT
Dynaudio Monitors
PreSonus Temblor 10 Sub
Check my Music out here:
Paul G YouTube
Paul G Bandcamp
Old 02-23-2021, 10:31 AM
I will test this thank you all
Old 02-23-2021, 11:44 AM
Emcha_audio's Avatar
Default Re: wave deformee
Utilise tu un expander avant l'input?
Manny.
Wave-T.com
Old 02-23-2021, 12:04 PM
The Weed's Avatar
The Weed The Weed is online now
I don't think it's Rectified View, but you could check that too.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 02-24-2021, 07:40 AM
bonjour
non pas du tout une simple pedale over drive
Old 02-25-2021, 08:29 AM
bad power supply somewhere in the chain
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 02-26-2021, 08:07 PM
TRNCFRMCN TRNCFRMCN is offline
J Guess Jt Js The Pedal.
Phase.
There Js Only A Small Wave Necessary, To Yield Jnterference — See Corona.
Sent from my iMorse using Tapatalk.
A/D - Square Wave of Triangle Wave? jgiannis Pro Tools 10 9 03-18-2016 05:12 AM
Wave sounding doesn't match wave drawing Saekwolth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-15-2009 10:04 AM
Strange session state - display frozen, play/record strange pkcraft Pro Tools TDM Systems (Win) 2 06-04-2007 02:43 PM
Video acting strange with 6.1.1 Wave Driver murph16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 01-15-2004 08:39 PM
Strange behavior of Wave Driver mecanoiz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 12-31-2003 06:01 AM
