Old 01-18-2012, 02:44 PM
tim carter tim carter is offline
Default 'PCI' Cards and G5 PT's8
I'm running 7.4 on a G4... I simply want to step up to '8' and keep my PCI cards and my 3rd party Apogee card. Is there a G5 that will support these cards?
Mac G5, 10.5.8, 2 GB, Rosetta 800 w/X-HD Card, Control24, HD2, PT's 8
http://carterbrothersband.com/studio.cfm
Old 01-18-2012, 03:11 PM
Craig F Craig F is offline
Default Re: 'PCI' Cards and G5 PT's8
all but the last version that was PCIe (easy check is that it has 2 ethernet ports)
up to 8.0.1 but it's not the best version ever
Thank you,
Craig
Old 01-18-2012, 04:56 PM
should I stay at 7.4? but get the G5?
Old 01-18-2012, 05:04 PM
8.x is workable but you may find 7.4 more stable
maybe split your OS drive so you can dual boot tom make your choice
Thank you,
Craig
Old 01-24-2012, 07:35 PM
I've just purchased a pre-intell G5, my PCI Cards should work with this computer right?
Old 01-24-2012, 08:24 PM
as long as it's not the last gen G5 with PCIe and 2 RJ-45 ethernet ports it should be fine
if your got the liquid cooled G5 check for leaks when you test your smoke detectors ever 6 months
Thank you,
Craig
Old 01-24-2012, 08:46 PM
Yeah, this has one ethernet port on the back.
Old 01-25-2012, 04:43 AM
Drew Mazurek's Avatar
I ran PT8 on a Dual 2.3 G5 for years. It was ok. 8's new graphics do slow it down compared to 7.4. You might want to do 2 partitions.
www.drewmazurek.com
Old 01-25-2012, 09:18 AM
woodsdenis woodsdenis is offline
Still use a dual 2.5. I would stick with 7.4.10 on Tiger. Rock solid.
Denis
Mac Pro 3.3 hexacore
24 gb RAM
Lion
PT 10 HD Native
Old 01-25-2012, 09:27 AM
I've been advised to replace the boot drive... anyone know exactly what drive it is and the best place to get one?
Are all pcie cord cards, accel cards? fourthtunz Pro Tools TDM Systems (Mac) 2 11-20-2011 08:41 AM
What is the thermal output/heat load of HD core cards and process cards? yosemitesam Pro Tools TDM Systems (Mac) 0 10-24-2011 02:39 PM
PCIe cards not being recognized in my MAC PRO ProTools not launching with cards in phatbeatstudio Pro Tools TDM Systems (Mac) 6 10-15-2011 11:35 PM
HELP!!! running 2 core cards on mix sys & lights on cards??? HELP!!! A Spooner Tips & Tricks 6 07-08-2009 06:55 PM
5.1 master, meter is LCR only? (PT's8) TCDet Post - Surround - Video 0 05-27-2009 08:04 PM
