Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 03-28-2013, 01:20 PM
junkgear's Avatar
junkgear junkgear is offline
Default Re: No midi drums to liquid safire 56
If your Safire is not responding to MIDI messages (light not blinking) then there are most likely two culprits; the sender (Roland drums) or the receiver (Liquid Safire). It sounds like the drums were working, so I would just make sure that noting has changed that would stop sending MIDI. If you have another MIDI device, I would connect it to your Safire and see if it makes a difference.
On the Safire side, has anything changed? Was there a driver update or any other software installed between the time it worked and the time it stopped working? You could always try unplugging the Safire, removing the drivers, reinstalling the latest drivers to see if it will correct the problem.
Old 03-30-2013, 07:15 PM
cwsand's Avatar
cwsand cwsand is offline
+1 to this. IF your using Windows 7, you might go as far as removing both the Saffire and 1394 Firewire devices from Device Manager, then scan for changes and let the firewire card reinstall. Then power on your Saffire and let Windows "rediscover" it.
Chris
Help Us Help You
Chris
__________________________________________________
Focusrite Liquid Saffire 56
TCE Studio Konnekt 48
PreSonus Digimax LT
Gigabyte GA-Z170-HD3P / i7 6700K 4.1 GHz / 32GB Crucial DDR4
macOS High Sierra Version 10.13.6
Pro Tools HD 2019.6
Adding MIDI drums to acoustic drums - Velocity Pat.m Pro Tools 11 5 11-01-2013 09:40 PM
advice/ Focusrite safire 2i2 ? drumbit Third Party Interfaces 1 05-16-2013 05:29 PM
Replacement for Digi 003r..Focusrite Safire Pro 40..? Piers Gibbon macOS 14 02-11-2013 07:17 PM
Focusrite Safire 56 hotstuff Pro Tools 9 0 11-19-2010 02:54 PM
Pro Tools 8 & Ueberschall Liquid Drums saxmanreed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-10-2009 03:45 PM
