Go Back   Avid Pro Audio Community > Pro Mixing > System 5
Old 07-08-2018, 03:09 AM
tobbelito tobbelito is offline
Default DSP Pilot crashing when changing mixer model
eMix 6.0
System 5 Fusion
Dsp crashes when I change mixer model from 96k to 48k.
Any ideas?
Old 07-09-2018, 07:37 PM
EddieJones's Avatar
Default Re: DSP Pilot crashing when changing mixer model
Pretty sure the DSP Pilot should not be running when you change mixer model. After you change the model do you power down EVERYTHING and restart ?
Old 07-09-2018, 07:38 PM
EddieJones's Avatar
Also latest version is 6.1
Old 07-10-2018, 05:30 AM
Dsp Pilot is running in the background all the time....
Connected is 401, 408, switch, SC264, Sync HD set to 48k int.
Old 07-10-2018, 05:33 AM
123
Old 07-10-2018, 05:40 AM
123
Old 07-10-2018, 08:14 PM
EddieJones's Avatar
Doesnt really answer they question....if you restart the whole system is does the new mixer model work ?
Old 07-10-2018, 08:16 PM
Nope..... no matter how many reboots, restarts. It wont operate at 48k.
Could the install be missing something?
Old 07-10-2018, 08:34 PM
EddieJones's Avatar
Can you try and get me the logs (i'm not sure where at the moment, but can find out tomorrow)
Old 07-11-2018, 12:45 AM
Found it. Was the Pilot 1 Properties/General/Source and Base Rate that was set wrong.
All good now 😁😁
PTHD 10 crashing when changing # of chips or sample rate dtmprod Pro Tools 10 2 10-23-2015 12:17 AM
Help With Pro Tools Mixer, Changing the size? beto515 Windows 2 01-02-2013 08:31 PM
PT 10.1 crashing when changing I/O settings. sretepmada macOS 5 06-15-2012 12:03 PM
Changing the colors on the mixer in Pro Tools? bmm4ever Pro Tools M-Powered (Mac) 1 11-27-2007 12:26 AM
Changing the color of PT mixer / interface? StrykeBack General Discussion 4 12-06-2006 05:29 PM
