Dithering question about SmartCode Encoder Encoder
This is a technical question about Smart Code PRO Dolby Encoder, version 1.2
when I use the encoder in Pro Tools 5.3.1, as an Audiosuite Plugin, and I wish to encode 6 24 bit WAV files, does the plug in apply dithering in the encoding stage, via the standard Digidesign Audiosuite Dither, or the resultant AC3 file will be truncated to 16 bit? The fact that Smart Encoder accept 24 bit input files could assure that the dither stage is embedded within the encoder? Thanks AJP
We always keep on trying |
Re: Dithering question about SmartCode Encoder Encoder
Would like to know this to. I started with bouncig with dither to 16bits .wav but lately use to stay in 24 bits. [img]images/icons/frown.gif[/img]
MBP early 2011. Apple MacPro 5.1 12Core ”Westmere”. DeckLink HD Extreme 3D+. OS X10.10.5 PTN|10-11. PTN|HD|10-11-12. 16 x 16 HD I/O - 16 x 16 192 I/O Lots of gear. http://www.mmvstudios.com |
thanks for intrest on my query...
But here's no one actually can explain this! Anyonelse opinion?
This is a moot point. The dithering in the Audiosuite process is on the resulting audio file. With the SCP stuff the resulting audio file is deleted by you once you've done the process (by either undoing the process or by manully deleting).
It's the resulting ac3 or dts file that you really want and that's not affected by Audiosuite dithering because it's not a product of the normal Audiosuite process. Therefore, you can have the AS dithering preference set to whatever you want because it doesn't affect this specifc case. (Most of that won't make sense to people who aren't familiar with the way the SCP plugs differ to normal Audiosuite plugs)
Cool & Informative Video Tutorials from Groove3 |
Encoder Assignment Question. | teacherman | ICON & C|24 | 1 | 01-23-2008 01:10 PM |
D-Command Pan Encoder Question | Reckless Erik | ICON & C|24 | 3 | 05-31-2007 02:57 PM |
Digi MP3 Encoder Question | skyevox1 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-28-2005 11:27 AM |
Dithering question about Smart Code PRO Dolby Encoder | poldo | Post - Surround - Video | 10 | 08-20-2003 03:35 AM |
DIGI- MP3 Encoder... Question... | Voxvendor | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-23-2002 01:35 PM |
