Old 07-17-2014, 03:28 PM
bandol79 bandol79 is offline
Default Eleven Rack latency on recorded audio
I hope that someone could possibly help me with this.
I have connected my Eleven Rack digitally from its AES/EBU output to my I/O 8x8x8's AES/EBU input. This has worked for me perfectly over the last two years, but after my first Eleven Rack gave up its ghost and I got a refurbished one as a replacement from Avid I've had huge problems with latency in this setup.
I have low latency monitoring activated with a H/W buffer size of 32 Samples and I still get around 75 ms of latency on all audio coming from my Eleven Rack. What is interesting is that all audio also gets recorded with this latency and I later have to adjust this by nudging the audio into place.
I have listened to the audio coming straight out of the headphones output of the Eleven Rack and that is in perfect sync with what I play, but for some reason I can't get it to be like this in ProTools.
Anyone have any ideas of what this could be, I appreciate any kind of help right now because this is starting to drive me crazy.
Old 07-17-2014, 04:20 PM
Pingafuego Pingafuego is offline
Default Re: Eleven Rack latency on recorded audio
I get latency if I output the Eleven Rack's recording track to a bus.
Check if your armed track's output is set to a bus instead of Output 1-2.
Old 07-17-2014, 04:35 PM
I have it set to my main output which is my Digital 1-2 out, so I don't think that is it. Also that shouldn't effect the audio that has been recorded, only what I monitor while recording. I also have problems with a audio "beep" after I have stopped recording. So I am wondering if I might not have a problem with the AES cable.
River Of Thorns New CD COMPLETELY recorded via Eleven Rack River Of Thorns Eleven Rack 1 10-28-2012 11:20 AM
Track recorded with Eleven Rack guitars Eric Tannery Eleven Rack 4 07-10-2012 01:22 PM
Metal/Electro/Rock project, recorded with the Eleven Rack Deathstar666 Eleven Rack 2 12-04-2011 09:10 AM
Metal Song, recorded with Eleven Rack! Deathstar666 Eleven Rack 19 10-31-2011 07:17 PM
Pro Tools 8 w/ Eleven Rack: I can't hear my recorded audio! zenabi916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-02-2011 06:54 AM
