Loop stop problem - video inside
When I have a loop set and it's playing, when I press the space bar to stop it, it gets rid of the loop points, how can I stop this from happening?
http://s301.photobucket.com/albums/n...ProTools-1.flv |
Re: Loop stop problem - video inside
Setup->Preferences->"Operation" Tab->Make sure "Timeline/Insertion Play Start Marker Follows Playback" is unchecked
Or Just hit the letter "N" with Command Focus turned on to toggle between between settings.
iMac 20" 2.4Ghz Intel Core 2 Duo, 4GB 667 Mhz DDR2 SDRAM, Guitar Rig Session I/O, M-Audio Axiom25, Pro Tools 10.1.3, Mackie Mr8mkII Monitors |
When I do that though, and then press space to stop it, the insertion line doesn't stay at where I stop it, it goes back to the start of the loop.
So you want to stop the playback in the middle of the loop and but keep the loop points?
Exactly
Dynamic transport should do the trick.
@theaudiogeek | www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com | |
that's what i was thinking, im trying but i cant figure it out to do what he wants
I know, I've tried so hard to work it out, Logic does it standard
If you unlink timeline and edit selection (one of the blue buttons below the tools) I think it will do what you want, Logic/Cubase style. This is not how I work in PT unless I'm working on MIDI a few bars at a time.
I still haven't figured out a way to do this, anybody else?
Pro Tools 8.0.3 Problem (Video Inside) - Please Read | eviani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 05-10-2010 06:11 PM |
Pro Tools 8.0.3 Problems (Video Inside) - Please Help | eviani | Pro Tools M-Powered (Win) | 3 | 05-08-2010 05:55 PM |
Anyway to Full Screen the video inside PT LE? | Rockman413 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-18-2009 05:19 PM |
A couple questions (video inside) | Scorpio253 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 02-24-2009 09:52 PM |
Grounding Problem INSIDE my Powermac? NOW WHAT? | Derek Doublin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 08-18-2004 12:20 PM |
