Old 09-24-2017, 08:59 PM
ea.byrne ea.byrne is offline
Default Boxes in front of Midi information [solved]
I'm getting these weird 'boxes' in front of every midi note I hit. It's making it very difficult to edit after I play. This wasn't happening before, but now everytime I make a track this happens.
Old 09-24-2017, 11:04 PM
Stig Eliassen's Avatar
Default Re: Boxes in front of Midi information
Welcome to the community.
What is your setup? Did anything change recently?
Old 09-25-2017, 04:29 AM
Not sure haven't used protools since 2009. I have an audiobox usb, protools 12, win7 64bit, 8 gigs ram, and the controller I'm using is an m-audio oxygen 8 us keyboard. All drivers are up to date. It sounds fine and works great, but it's near impossible to edit with these little boxes in the front of the midi info. Is it recording the contact hits too? If I slide the midi info around it actually leaves the box still there leaving me to have to go through and delete those little guys one by one. It's gotta be a setting or a switch somewhere right ???
Old 09-25-2017, 04:36 AM
How do you have the keyboard connected to your computer - the USB connection or round 5 pin MIDI connection? You can't use both. It looks like you have some kind of looping going on in the MIDI connection. You're on Windows so I'd suggest getting MIDI-ox - it's a free utility that'll show you what's coming over your MIDI connection.
Jack
QAPLA!
Old 09-25-2017, 04:38 AM
Marsdy Marsdy is offline
At a guess I would say your m-audio controller is sending out double notes, maybe because two zones are enabled or something. I used to do this by accident a lot with my old keystation 88
Dave Marsden
UK
It's just connected by usb into a port on the computer. This is something that happened in the middle of a session where two instrument tracks were working fine, then I tried to create new instrument tracks and this started happening.
Old 09-25-2017, 04:42 AM
Marsdy that's exactly what it looks like or feels like when you say it's sending two notes because two zones are available. My midi keyboard stopped working for a bit and did some trouble shooting. I may have screwed something up along the way. How would I get the controller to only be in one place or zone to prevent it from sending out a double signal. Both the little box and the midi info on the same line play the same note or hit
Old 09-25-2017, 05:10 AM
Drew Mazurek's Avatar
google "pro tools double midi notes"
Here's one of the results. Maybe this will help.
https://www.youtube.com/watch?v=xwFM0LfCsH0
www.drewmazurek.com
Old 09-25-2017, 09:16 AM
Drew Mazurek, ya did it bud! That fixed it, I was about to lose my mind, I have never come across that problem before. Thanks dude, and thanks to everyone as well, much appreciated!
Old 09-25-2017, 09:52 AM
excellent!!
www.drewmazurek.com
[solved] RACK 003 + PT9: front switchs problem! coboune 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-26-2011 10:22 AM
Strange problem solved.. for your information coosticks Pro Tools TDM Systems (Mac) 1 10-31-2006 05:11 AM
Advice - Midi Fader Boxes sh336697 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-03-2005 07:16 PM
Midi interface boxes 3Dbuddah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-23-2002 03:17 PM
Mic pre's and Midi Boxes??????? Seller Pro Tools TDM Systems (Mac) 4 04-20-2002 11:53 AM
